I've got a serious problem!!
Old Aug 20, 2011 | 07:59 AM
XxK1LLAxX's Avatar
Ok guys i need your help...I have no idea what happened to my car. You can see from the pictures all the oil everywhere...looks like it was coming from the back left side of the engine somewhere because thats where there is the most oil...There is also a light gray type of smoke coming from the exhaust..The car feels very unresponsive if you try and drive it.....I need a diagnosis please!!
Old Aug 20, 2011 | 08:11 AM
2003lancerevo8's Avatar
I would start by pulling off the oil pan and checking if you have any surprises in there.....
would not try to drive it, more than likely making the issue worse
Old Aug 20, 2011 | 08:13 AM
dastallion951's Avatar
best bet is to pressure wash under the hood, put a dye into your oil, and check with some special glasses where its leakin from, best bet, no way to tell where its leakin from as of now in your pics man. Good luck
Old Aug 20, 2011 | 08:16 AM
milford's Avatar
your dip stick blew out. happens all the time. put a spring on it or install a proper catch can set up.
Old Aug 20, 2011 | 08:17 AM
evoxsi's Avatar
i would check ur pcv and line, then double check the oil cap. dont drive it. the fact that oil is all over the top of the valve cover make me think its something leaking fron the head.
Old Aug 20, 2011 | 08:18 AM
sparky's Avatar
Good call on the pressure wash and the dye! My question is: When the OP states that the likely source of the leak is the left side of the engine, is he referring to the passenger side, or the driver's side of the engine?
Old Aug 20, 2011 | 08:19 AM
XxK1LLAxX's Avatar
i just got a new oil cap and put a new pcv valve on it like a month ago...it also has a catch can installed.
Old Aug 20, 2011 | 08:29 AM
SmurfZilla's Avatar
i think the passengr side (looking at car head on)
Old Aug 20, 2011 | 08:35 AM
XxK1LLAxX's Avatar
My bad yes it is the passenger side..
Old Aug 20, 2011 | 08:58 AM
4RETECH's Avatar
Was you dipstick out when you saw this. Seems to be the cause.
Wash down the engine, top off the oil,secure the dipstick and drive again.
Check it after your drive.
Old Aug 20, 2011 | 09:05 AM
browningderek's Avatar
Check compression! Mine shot oil from around the oil filler cap when my first motor went.
Old Aug 20, 2011 | 09:27 AM
sr20detisbetter's Avatar
Head is leaking. Prob head gasket went which would explain gray smoke out of exhaust
Old Aug 20, 2011 | 09:29 AM
In2Speed's Avatar
Dipstick! Very common problem
Old Aug 20, 2011 | 09:40 AM
Why would the dipstick popping out cause gray smoke out of the exhaust?
Old Aug 20, 2011 | 09:47 AM
jr_2006IXMR's Avatar
Wow hope all of these suggestions are helpful.
