No injector pulse!!!
Old Aug 26, 2011 | 08:00 AM
CWiLL's Avatar
I have a car with no injector pulse. Came in with a burnt ground wire, the one that sits by the cam angle sensor on the head. Ive pulled the harness apart fixed the wire and check all the injector wires (all good). Other thing was the main ground wire to the tranny was loose so that explains why the little ground wire was burnt, im pretty sure.
What are other reasons that the injector have no pulse?
BTW 06 Evo gsr
Old Aug 26, 2011 | 08:10 AM
Jesus29's Avatar
Resistor box, check that and check for ground problems with it too...
Old Aug 26, 2011 | 10:45 AM
wreckleford's Avatar
Swap the ECU. Check the fuses.
Old Aug 28, 2011 | 06:10 AM
brt426's Avatar
Immobiliser
Hello,
I had a similar problem with a lancer, not Evo, and my mate tried to start the car with a key that wasn't programmed to suit that car.
Gave error code 41 I think. Upon checking the workshop manual, the immobilser is the only thing that actually cut's the injectors.
I hope this helps.
Cheers
Old Aug 28, 2011 | 04:52 PM
CO_VR4's Avatar
Have you confirmed your crank sensor is working properly?
Old Aug 29, 2011 | 07:01 AM
CWiLL's Avatar
the key is right. ive swaped Resistor box. checked all fuses. swapped ecu. if you log the car cranking it shows 187rpms so a quick look would seem the crank angle sensor is picking up something else it wouldnt have an rpm signal
Old Oct 2, 2011 | 03:31 AM
mrtalon20's Avatar
I had the same problem man it turned out to be my engine harness.
Old Oct 2, 2011 | 05:10 AM
jameswwt's Avatar
Originally Posted by brt426
Hello,
I hope this helps.
Cheers
My friend been thru the same problem on his Evo VI RSII..
boosted91t
20
Jan 13, 2016 06:34 PM
Ben2904
Dec 25, 2015 04:52 AM
robertbaileyiv
Aug 26, 2015 11:23 AM
ExtremeDSM
Nov 20, 2013 11:54 AM
toxic-evo
AEM EMS
Mar 16, 2012 02:20 PM
