Rear Diff fluid?
Old Aug 28, 2011 | 02:32 PM
Redbud23's Avatar
Veteran: Marine Corp
Rear Diff fluid?
I am going to work on my rear diff next weekend and replace the output seals that are slightly moist. I was getting everything ready and was wondering what is the best fluid for the rear diff? I know it is a limited slip diff and it needs to have the right fluid. I was thinking Redline heavy duty shock proof, but was hoping some of you could help me out with whats best. Thanks for any help.
Old Aug 28, 2011 | 02:34 PM
sujinX's Avatar
https://www.evolutionm.net/forums/ev...uantities.html
Old Aug 28, 2011 | 02:49 PM
Redbud23's Avatar
I read the post and it says Mitsu diaqueen lsd fluid which i have, but I was really wondering if there is better fluids to put in the diff. Thanks
Old Aug 28, 2011 | 03:26 PM
RallyBud's Avatar
In another thread a member mentioned that Jon from TRE recommends Redline 80W140 GL-5 for the rear differential.
Old Aug 28, 2011 | 04:53 PM
EvoJoeIX's Avatar
i wouldnt use anything other then OEM fluid in the rear diff and transfer case
Old Aug 28, 2011 | 07:36 PM
Kracka's Avatar
I agree with this dude. Diaqueen 90W LSD for me.
Old Aug 28, 2011 | 07:42 PM
wizzo 8's Avatar
I have the same problem and will be replacing the left output shaft seal. I'm going with redline heavyweight oil. If it doesn't work out then ill go back to OEM.
Old Aug 28, 2011 | 10:16 PM
R/TErnie's Avatar
I used Redline NS (non slip) 75w-140 with a tiny bit of friction modifier as well....although you probably won't need much.
This will make your diff in the rear lock up much better...especially if you haven't had Jon @ TRE do a MAX LOCK conversion for you. Worth the money IMO!
I run Diaqueen or the Redline NS depending on whether I'm tracking the car or driving it on the street. OEM Diaqueen for the street.
http://www.teamrip.com/EVOLUTION%20R...20SERVICE.html
Old Aug 29, 2011 | 05:59 AM
RJSP's Avatar
Friction modifier
[quote=R/TErnie;9566811]I used Redline NS (non slip) 75w-140 with a tiny bit of friction modifier as well....although you probably won't need much.
I recently had the rear differential serviced and "fixed" for max lock by rearranging the friction plates as in the manual. I do get the very low speed turning chatter.
So I wonder if I could use a little of Militec 1 as a friction modifier, don´t have acces to redline products here in Peru.
Thanks,
Ricardo
Old Aug 29, 2011 | 06:48 AM
R/TErnie's Avatar
Ricardo if you want zero chatter use the diaqueen, or start adding friction modifier
Old Aug 29, 2011 | 08:04 AM
RJSP's Avatar
I currently use Liquimoly 75-90W synthetic syncro gear oil, it is one of the best available in Peru. The are probably no more than 40 - 50 Evos in Peru, so Mitsu doesn´t have Diaqueen readily available.
Do you think Militec 1 (metal treatment) would work the same as Red Line´s friction modifier? If not I can try to import a bottle of Red Line´s stuff. Also there are other "friction modifiers" here like Qualikote (Sonax) and another one from Liquimoly as well. How many onces is required to stop the chatter?
It really doesn´t bother much, only when backing out of driveway, but I do like a lot how it performs in AutoX compared to how it was before.
Thanks for your help,
Ricardo
Old Sep 7, 2011 | 09:11 AM
devoadam2's Avatar
Rear Diff fluid?
oem fluid is great if u can get schaeffers we run that in diffs and trans we run dog box but as for diffs they last a whole lot longer and lsd plates and basket dont wear as bad as oem my diffs are set to 8kg rear and 10 front and they last 3 rally crosses vs 1 and rebuilding it
Old Sep 7, 2011 | 08:50 PM
wizzo 8's Avatar
Well I replaced the seal and its holding now. Only problem now is Im getting a shudder from the rear end now on slow turns. Im going to add some friction modifier to hopefully fix it. If not then I will have to change to a different fluid.
Old Sep 24, 2011 | 02:28 AM
kijima's Avatar
Castrol SAF-XA?
Old Sep 27, 2011 | 11:04 AM
SuperchargedGTZ's Avatar
stupid question...but how easy is it to replace the seals...
and can you describe this "shudder"...i think i am getting the same thing. usually when i started to get this shudder i thought it was taking a dump and ended up just replacing it with a used one...
