Difference between piston 2&3
Old Sep 12, 2011 | 03:54 AM
sinsim's Avatar
just wondering..is there a difference in the between piston # 2 nd #3 at TDA (top dead center)? my mechanic pointed that out to me that my piston # 2 is 2mm lower than the #3 piston..is that a normal thing
i would appreciate all the help that i can get
Old Sep 12, 2011 | 06:37 AM
Aby@MIL.SPEC's Avatar
wow, 2mm difference.... possible bent rod.
1-4 pistons are the same.
Old Sep 12, 2011 | 07:51 AM
barneyb's Avatar
Two millimeters isn't all that much considering the junk that can collect on the top of pistons.
Old Sep 12, 2011 | 08:03 AM
Piro Fyre's Avatar
If it's just carbon build up that's making it a 2mm difference, it's not a big deal. You can scrape it off the piston just fine. BUT if it's just measuring the pistons, than it's a big difference and there could be a problem. As what Aby said, could be a bend rod.
Old Sep 12, 2011 | 09:52 AM
2mm = ~.080
a oem gasket is ~0.047 / 5 layer... if the piston is below the deck by ~0.020, the piston w/carbon would be hitting the squish band portion of the cylinder head.
Old Sep 12, 2011 | 05:32 PM
sinsim's Avatar
but it doesn't bind or resist when rotating by hand any of the pistons
Old Sep 12, 2011 | 05:41 PM
RSMike's Avatar
what does a compression test show up?
if the piston is physically lower because the rod is bent, the compression on that same cylinder will be low
Old Sep 12, 2011 | 08:19 PM
sinsim's Avatar
we dont know that yet because the motor is taken apart..im actually changing my head
Old Sep 12, 2011 | 08:27 PM
sinsim's Avatar
here are some pics
Attached Thumbnails Difference between piston 2&3-dscn8984.jpg   Difference between piston 2&3-dscn8988-1-.jpg
Old Sep 12, 2011 | 10:59 PM
EVODreams's Avatar
I would suggest disassembly to inspect. That is not normal and there has to be a reason for it.
Old Sep 12, 2011 | 11:07 PM
FX11's Avatar
this
Silver-IXse
Aug 12, 2013 11:45 PM
boosted91t
Dec 26, 2012 08:41 AM
MR BURTON69
May 18, 2011 07:27 PM
project95gsx
Jun 1, 2009 11:08 AM
turboj
Aug 20, 2007 03:19 AM
