ticking/knocking sound at idle
Old Feb 21, 2013 | 03:18 AM
  #121
evoyrrah's Avatar
Do you have a link for this mod? Could it be that gasket is not thick enough? Maybe piston to valve clearance is too close???
Old Feb 21, 2013 | 06:40 AM
  #122
evoxsi's Avatar
thats ehy im gonna try the 9 gasket cause my head was decked twice. just search "4g63 oil passage mod" and it should be the first one.
Old Mar 2, 2013 | 11:58 AM
  #123
evoxsi's Avatar
9 head gasket plus timing belt setup ordered. head will come off next week if i get the parts in time before i leave for st paddys day shenanigans.
Old Mar 3, 2013 | 04:04 AM
  #124
evoyrrah's Avatar
Keep us posted mate.... I may have to do the same mod as my head has been milled like 4-5 times
Old Mar 9, 2013 | 05:03 PM
  #125
evoxsi's Avatar
head is off and so far nothing suspicious other than buildups on the valvestems and piston tops. i took picks but cant get them loaded up from my iphone. tomorrow i will be tearing the head down to inspect the valves and try to clean the piston tops.
i do think that the culprit might be the 8 head gasket though as the 9 looks twice as thick.
i will keep this updated as i inspect everything.
Old Mar 11, 2013 | 04:35 AM
  #126
evoxsi's Avatar
yesterday i completed the the head mods. oil passage porting, egr tap/delete. i also cleaned up the valves, combustion chambers, piston tops, intake manifold. i was on the fence about doing the egr mod but once i saw how gummed up my intake manifold, intak evalves and piston tops were it was a must.
i had buildups on some of the actual valve seats in the head that looked like some of the valves were not fully closing. i also checked pistons for play. they all could be rocked when brought to tdc but there was no up and down play. idk how much movement there should be but i took a video of it to show.
today im gonna be doing the timing/balance belt change and try toget the head back on.
Old Mar 11, 2013 | 04:45 AM
  #127
evoxsi's Avatar
some pics
Attached Thumbnails ticking/knocking sound at idle-image.jpg
Old Mar 11, 2013 | 04:46 AM
  #128
evoxsi's Avatar
wont let me do more than one pic per post?
Old Mar 11, 2013 | 04:48 AM
  #129
evoxsi's Avatar
cylinder walls. no marks from a wrist pin in any cylinder. i didnt get a pic from that angle though.
Old Mar 11, 2013 | 04:51 AM
  #130
evoxsi's Avatar
all pics were before cleaning. ill take some today of them cleaned.
Old Mar 13, 2013 | 03:14 AM
  #131
evoxsi's Avatar
pistons cleaned of debris. didnt get to into it as i did not want to clog any galleys.
Old Mar 13, 2013 | 03:16 AM
  #132
evoxsi's Avatar
valves and combustion chamber cleaned of debris. again mostly just the buildups were taken away, nothing crazy as i left the valves installed.
Old Mar 16, 2013 | 03:56 AM
  #133
evoxsi's Avatar
ok ive only gotten about a half hour of driving on the clock but the sound remains. i believe it is piston slap and nothing else. if you look at the pic of the head you can see i still have alot of that oil galley remaining. i still modded it though as to make a better/softer angle to the port. in all im glad i took everything apart to see what my 28k old built motor looked like.
when i get back from my trip this weekend i will upload the video of the pistons rocking and someone who knows better can let me know what they think.
Old Mar 21, 2013 | 05:10 AM
  #134
TurboM3's Avatar
Registered User
Can you post a revised video with it starting cold and then warming up?
Old Apr 2, 2013 | 03:40 AM
  #135
evoxsi's Avatar
trying to upload from my phone but its wont let me.
