O-ringing substitute
Old Oct 31, 2011 | 01:48 PM
foxbat's Avatar
Got this high powered Evo that seems to need engine o-ringing, pressure is escaping through the head gasket when exceeding 32psi, I found this racing gasket online: http://www.scegaskets.com/ICS-Titan-...98873-1-2.html
Has anybody tried those before? It looks like a good substitute for or-ringing!
Old Oct 31, 2011 | 02:08 PM
BenJ's Avatar
I just run l19's and the factory gasket, 40+psi
Old Oct 31, 2011 | 02:19 PM
foxbat's Avatar
Hmm, how? I'm running .4 Tomi gasket & L19s too, but pressure still leaked at around 32psi, so I definitely need o-ringing, I just found about SCE gaskets & I wonder if they substitute regular o-ringing without the need for receiver grooving?
Old Oct 31, 2011 | 02:31 PM
RSMike's Avatar
Are your head and block surfaces perfectly flat?
what torque did you do the L19 studs to?
Old Oct 31, 2011 | 02:48 PM
foxbat's Avatar
Both are perfectly flat, as for the studs..as I recall is was 40 newtons +90 +90degrees.. does that sound right?
Old Oct 31, 2011 | 02:50 PM
Svendiesel's Avatar
Ive read about plenty of guys on here who dont have O-Rings and are running well into the 40+psi range with no leak issues. Very odd.
Old Oct 31, 2011 | 03:05 PM
foxbat's Avatar
My main question is still about the SCE gaskets, they seem to have embedded o-rings, are they a good substitute for traditional o-ringing? Do they still require receiver grooving? It would be great if I could have o-rings benefit without having to groove either the head or block!
Old Oct 31, 2011 | 03:16 PM
project_skyline's Avatar
A good substitute is having a block and head finish that is smooth as glass.
Old Oct 31, 2011 | 04:29 PM
bevolucion's Avatar
seems like a warped head. 32 psi is not an insane amount of boost. I always go 30 ft lb cycle, 60 ft lb cycle and finally 75 ft lb cycle on my head studs.
Old Oct 31, 2011 | 04:47 PM
RSMike's Avatar
H11/L19 head studs should be torqued to 100ft/lbs.
b16a95eg
69
Oct 16, 2017 02:29 PM
dw cuz
19
Nov 30, 2014 04:02 PM
kelvinTME
May 20, 2012 07:45 PM
fortyPSIrs
Nov 1, 2011 11:43 PM
benderrodriguez
24
Oct 23, 2011 09:45 PM
