Vacuum question for those running GSC S2s
Old Nov 7, 2011 | 03:39 PM
D Grade's Avatar
S2 users, how much vacuum (Hz) are you guys running at idle?
Old Nov 7, 2011 | 03:41 PM
tisthisevo's Avatar
10
Old Nov 7, 2011 | 04:18 PM
deadmeat's Avatar
My gauge is usually hovering at 10-11 at idle.
Sorry not sure what the conversion for Hz is
Old Nov 7, 2011 | 04:31 PM
D Grade's Avatar
Wow 10hz? Didn't think the s2s would read that low.
Old Nov 7, 2011 | 04:35 PM
vmrevo9's Avatar
Veteran: Air Force
mine reads around 10-12 vaccum on my boost gauge and on my evoscan it reads 43.75 - 50hz idle was at 1030-1090 rpm
Old Nov 7, 2011 | 04:39 PM
D Grade's Avatar
Awesome thank you!
Old Nov 7, 2011 | 04:40 PM
211Ratsbud's Avatar
Any fuel trim problems at idle ?
Old Nov 7, 2011 | 05:06 PM
D Grade's Avatar
Oh no, not at all. I'm still on stock cams and was wondering for knowledge sake as well as the fact Ill need to get a different Tial BOV spring when the switch happens. I wasn't expecting such a dramatic drop from -17/-18 right now at stock, to -10/-11 on S2's. S3's or a full 280 duration higher lift cam like HKS's maybe.
I woulda bought the wrong spring for sure.
Old Nov 7, 2011 | 08:31 PM
browningderek's Avatar
Yea, i think the softest tial spring goes with the S2/S3 cams, as well as my buschur's.
Old Nov 7, 2011 | 08:36 PM
boostedtres's Avatar
i have a crap mechanical boost gauge so its not going to be the most accurate, so take this with a grain of salt. Evo 8 stock turbo stock cams, idle around 20. sotck 8 turbo, S2 cams w/ full valvetrain, right around 9-10 depending on how i adjust the biss. usually right around 10. big difference, i was surprised big time too. idle is a little hard to dial in and diff when hard braking to a stop.
but the cams pull like a MF!!! they pull way harder up top than the lil 8 turbo can support. love these cams, def get them.
not going to compare dynos or anything like that, and this isnt a straight up comparison (bc thats not how i spend my money). but with the addition of the cams, IC piping (stock FMIC), and an intake, i gained approx 47whp.
yea i know, other mods, more boost, diff temps blah blah blah. just giving you an idea with stock 8 turbo. gl brotha
Old Nov 7, 2011 | 09:54 PM
D Grade's Avatar
Thank you very much. Yeah, I had my mind set on these cams. They definitely give quite a bit of HP on VIII 's and a lil on IX's and make a good difference uptop without sacrificing bottom end or mid range power.
Old Nov 8, 2011 | 09:26 AM
dastallion951's Avatar
to be honest man i think u meant in/HG inches of mercury aka vacuum haha, me personally on mine during cold start warm up wont even register my boost gauge will just shake somewhat haha then after like 5-10 seconds, it will rest about 10-11 like others.
Old Nov 8, 2011 | 04:55 PM
anthonyrb98's Avatar
mine is around -13 at idle
dsmtalontsi95
Aug 25, 2018 05:44 AM
Gary Frizado
Mar 20, 2017 09:48 PM
STIU2SLO
Sep 20, 2016 01:03 PM
maknuge
Dec 18, 2015 07:48 AM
Evo8Emperor
Oct 18, 2007 09:44 AM
