Aquamist hfs-3 fail safe question
Old Nov 19, 2011 | 01:19 PM
itsu's Avatar
So I pretty much have my aquamist hsf-3 completely installed, I'm now at the wiring point of the fail safe method. I don't fully understand the tephra method, So i'm going to be using the boost cut method, but if i'm using a manual boost controller is this even possible since it has to have signal from the BCS? I imagine i'm going to have to switch back to stock boost with the solenoid, unless there is another way to do this.
Old Nov 19, 2011 | 04:01 PM
mt057's Avatar
You can use a MAC Valve. Lots of info in the water/meth injection section of the forum and at www.waterinjection.info
www.howertonengineering.com has a lot of good info to.
Old Nov 20, 2011 | 10:54 AM
Migsubishi's Avatar
The mac valve like previously suggested is the best way, I have the same kit and use the mac valve with the safety feature to cut boost back to wastegate pressure in case something should fail.
R. Mutt
Dec 28, 2014 07:38 PM
EvilTechnology
Mar 1, 2013 04:02 PM
drifterific
16
Jun 29, 2012 04:54 PM
Darkn3s
28
Jul 7, 2010 01:56 PM
vroomevo
17
Dec 1, 2008 12:41 PM
