Annoying Tick... was it my injectors?
Old Nov 29, 2011 | 06:04 PM
Spec-Ops1's Avatar
So I have been running E85 for around 10 months straight now and for the past 2 months I have had a nasty tick I couldn't get rid of. It would only occur between 2000-4000 RPM. I swapped the lifters last week in hopes it would remedy this. To my dismay it did nothing...
A local member had some nasty E85 gunk on his injectors so I figured I would run a 1/4 tank of 93oct through the car to clean the injectors out, and low and behold the tick was gone within 5 miles!
Has anyone else experienced this annoying tick sound from the injectors while running E85 for extended periods?
Is there any kind of treatment I can use with E85 to lubricate the injectors to prevent this in the future?
Old Nov 29, 2011 | 06:15 PM
killerpenguin21's Avatar
oddly enough your the second person ive seen post about this in the past 24 hours. i think it was 4RETECH that just had a running problem after months of e85, ran 93 and it cleaned up.
i wonder if it was the e85 kicking up the deposits in the tank vs. crud in the e85?
Old Nov 29, 2011 | 06:24 PM
Spec-Ops1's Avatar
Didn't really have any of the problems he had... car starts and drives fine just ticked...
Old Nov 29, 2011 | 08:57 PM
mirkendargen's Avatar
My stock injectors ticked fairly loud, but it was just how they were, they never saw e85 obviously.
Old Nov 29, 2011 | 09:14 PM
i was at work so i couldnt find the thread/his exact issue, my bad.
Old Nov 29, 2011 | 09:19 PM
n2oiroc's Avatar
i know it sounds ghetto, but im sure a tiny amount of 2 stroke premix oil in the gas tank would help. you could also try an upper cylinder lubricant like marvel mystery oil or lucas makes one. either way, a very small amount.
Old Nov 30, 2011 | 02:35 AM
8UpUrV8's Avatar
Just curious, wouldn't the oil decrease the octane of your fuel? Does anybody know how much?
Old Nov 30, 2011 | 04:49 AM
Spec-Ops1's Avatar
I was thinking of adding some mineral oil to the mix...
Old Nov 30, 2011 | 07:12 AM
n2oiroc's Avatar
It would effectivly lower octane and lean out the mixture, dont know how much though. Thats why i said a very small amount.
Old Nov 30, 2011 | 07:27 AM
HIS Motorsports's Avatar
What injectors are you running Freddie?
Old Nov 30, 2011 | 07:40 AM
Spec-Ops1's Avatar
Kasey, I am running a set of the Bosch high-z 2000cc injectors...
Old Nov 30, 2011 | 07:44 AM
CurseDSM's Avatar
Seafoam works well for that problem as well as an alternitive. Just add a qauarter bottle to the gas and drive it around.
Old Nov 30, 2011 | 07:54 AM
Did you not take them out and look at them? I know pump gas will clean them out a little but not all the way.
Old Nov 30, 2011 | 08:02 AM
Spec-Ops1's Avatar
Not yet that is on my to do list when I change the cams this weekend... I have been super busy with Navy and my College classes
Old Nov 30, 2011 | 08:38 AM
Thats understandable!
Hassan
103
Aug 5, 2023 11:37 AM
Michael Cain
Nov 12, 2016 10:20 AM
BDecker9
Jul 27, 2016 11:28 AM
wolford240
Oct 28, 2013 11:55 AM
FiftyFive
17
Jan 5, 2008 12:07 PM
