Deatschwerks Fuel Hardwire kit ??
Old Dec 2, 2011 | 08:11 AM
catman78's Avatar
Hi all,
Anyone use this install kit? If so I have question regarding wire splice.
As per instructions:
7. Splice the black wire from the relay socket to the chassis side of the pump 12v/pos wire.
8. Splice the yellow wire from the relay socket to the pump side of the pump 12v/pos wire.
Which is the chassis side of the pump 12v and pump side of 12v pump?
Are the thicker black/white wires from pump switch only ones spliced.
Old Dec 22, 2011 | 04:55 PM
turbodsm420's Avatar
im wondering the same thing. no one knows come on
Old Dec 22, 2011 | 04:57 PM
REV.olution's Avatar
Easy. Cut the white wire in half. The white wire is the positive line within the pump's harness. Now that the wire is cut in half, find the end that is connected to the car's harness. This line is no longer connected to the fuel pump. Connect that line to the black relay wire on your dw kit. The end that is still connected to the fuel pump connects to the yellow wire. When finished, each end of the white wire should be tapped.
Old Dec 23, 2011 | 02:25 AM
catman78's Avatar
I figured it out the day I posted the thread.
It's the language of the instructions that was a bit confusing.
Pump side = wire coming FROM pump switch.
Chassis side = wire to ECU.
I believe the instructions are universal, not car specific.
My Walbro is a bit louder after the re-wire
Old Dec 23, 2011 | 09:40 AM
thanks
Boltz.
Sep 23, 2014 01:04 PM
Boltz.
For Sale - Cars For Sale
22
Jan 12, 2013 12:01 AM
Lethal_427
27
Aug 23, 2012 12:34 PM
apex electric
Aug 18, 2012 09:56 AM
glamcem
19
Oct 18, 2011 07:15 PM
