cam choice
Old Jan 6, 2012 | 04:39 AM
stunt2's Avatar
cam choice
looking for relatively cheap 272 cams for 2.3 stroker with stock turbo. which way to go, BC or HKS ?
Old Jan 6, 2012 | 06:26 AM
Hendrixmx's Avatar
Gsc!!
Old Jan 6, 2012 | 06:36 AM
escodotcarter's Avatar
op, both of those a bad choices. go with either gsc s2 of kelford 272 and call it a day. Its been beaten to death a zillion times.
Old Jan 6, 2012 | 06:37 AM
grillpt's Avatar
+1 Good advise.
Old Jan 6, 2012 | 07:26 AM
stunt2's Avatar
wanted to screw out without changing valve springs, retainers, and +400-500$ for cams
what's wrong with HKS 272 ?
Old Jan 6, 2012 | 08:03 AM
Derekes1's Avatar
you pay for what cha get kido. Kelford.
Old Jan 6, 2012 | 08:06 AM
notjdm05MR's Avatar
GSC S1's, you don't have to change out springs or retainers!
Old Jan 6, 2012 | 08:10 AM
Aby@MIL.SPEC's Avatar
there are some hks 280 cams for sale on socal evo for ~225 iirc.
gsc s2's, kelford 272's or hks 280's
Old Jan 6, 2012 | 08:15 AM
JonahEVO's Avatar
GSC hands down...
Old Jan 6, 2012 | 08:57 AM
stunt2's Avatar
HKS 280's don't require spring change ? can you compare HKS 272 vs 280 ? in daily drveability and spool side
Old Jan 6, 2012 | 09:04 AM
meckert's Avatar
It might be better if you explain the kind of spool, power range (RPM band) and HP you are going for ---that will narrow decsions and recommendations.
Old Jan 6, 2012 | 09:23 AM
stunt2's Avatar
car would be mainly daily driver, and some autoX also. rmp range till around 8000. 2.3 stroker, 10.5 hotside turbo. not going for huge power levels or laggy turbo, just looking for quick spool and torquish street car, that would't be dead on higher rpms too
Old Jan 6, 2012 | 11:09 AM
JohnBradley's Avatar
If you spent the money on the 2.3, why not spend the money of the valvesprings? The full Ti retainer kit from GSC is $390. The S2s and springs will compliment the build nicely.
Aaron
Old Jan 6, 2012 | 11:10 AM
a stock turbo wont make power to 8k. i have run s2's on a 2.3 with oem turbo/10.5 & power will fall off @ ~6k, as the turbo will simply be out of breath.
my personal experience on a 2.0L on 91oct, hks cams only, the 272's drive & idle better than the 280's. What you give up down low, you gain up top with the 280's.
who is doing the work & tuning on your car?
if it's you, then going the inexpensive route is fine, as you can buy sell as you please. lets face it, a cam swap is 2 hours from hood up to hood down & off to tuning.
but if your paying for installs & tunes, do it right the 1st time & go for s2's. it will be cheaper over the long haul.
yeah, there are other cams that make more power than the hks 272's or hks 280's, but your current turbo set-up really wont show the full benefits of the better / more expensive cams.
what work has been done to your cylinder head?
Old Jan 6, 2012 | 11:43 AM
stunt2's Avatar
@ Aby@MIL.SPEC
luckily I'm not paying for mechanic's job or for tuning, doing both myself.
the head is untouched as far as I know, bought the car already stroked
p.s. sent you PM, might check it
