3 port catch can?
Old Jan 9, 2012 | 07:38 PM
Steven's Avatar
3 port catch can?
Why is there so few 3 port catch cans? I'd like to tie the 2 valve cover fittings to a catch can, and have the outlet go to the turbo suction. There are so many vehicles with 2 valve cover vents, but very few people do it this way. I've only found a couple catch cans with 2 inlets and 1 outlet. Is there some reason that this isn't done very often?
Old Jan 10, 2012 | 10:18 AM
Steven's Avatar
Bump
Old Jan 10, 2012 | 10:26 AM
Sirnixalot's Avatar
i got a custom can from a guy that does them on dsmtuners.com username is Calan. They are filtered and baffled.
http://www.dsmtuners.com/classifieds...ch-cans-24769/
The price was awesome and i am very happy with my can.
I know its on the wrong side etc but you get the idea
Old Jan 10, 2012 | 01:21 PM
MitsuJDM's Avatar
It may not look as nice, but I have mine set up this way; It's a two port. I just used a "T" fitting and put the PCV and breather hose into one going into the catch can and then recirculating into the intake behind the MAF.
Old Jan 10, 2012 | 01:28 PM
B.J.@ToxicFab's Avatar
Nice, setup looks pretty good, I like it.
Old Jan 10, 2012 | 01:46 PM
Balrok's Avatar
I've been waiting for something proper like this for awhile.
Old Jan 10, 2012 | 01:55 PM
304MR's Avatar
I think toxicfab needs to get into the catch can biz.
Old Jan 10, 2012 | 04:01 PM
Steven's Avatar
I really like that can. Saikou Michi just got back with me and says that he makes them too. He's got a couple pics that looked nice. Tough decisions!
Old Jan 10, 2012 | 04:08 PM
Collin has built multiple different catch can setups, seems like everyone wants something different. Everyones setup/engine bay are different so its hard to make a good catch can that is "1 size fits all". He can build whatever a customer wants, all depends what you are looking for, where you want to mount it, how many inlets/outlets, sealed vs. vented, how much the customer wants to spend, etc...
Old Jan 10, 2012 | 07:01 PM
Sirnixalot's Avatar
VTA is not the way to go in my humble opinion.
The lines from the valve cover and the line to the intake are all -8an.
I had to remove the stock baffles to make sure i got all the shavings out and re-baffled the holes for the ports (using a much simpler method).
The suction port for the can on the intake was entered at an angle and notched on the leading edge to allow the air passing through that notch to help pull on the air/vapor in the tube.
On the PCV side i deleted the stock one and am using a single 3/8" plastic check valve.
So far with 300km on the motor the can's view sight appears clean, though i need to open the drain and see if there is anything inside. The check valve shows no oil residue on the inside.
Old Mar 14, 2012 | 11:24 AM
STIKiller4G63's Avatar
after reading this...what if I have a 2 port catch can and i just connect a T-fitting to the lines before it reaches the catch can, and then shooting into the intake....does this create the same affect or it limited because its still joining into one line so therefore wont really do much for crankcase pressure?
Old Mar 14, 2012 | 06:15 PM
Steven's Avatar
I believe you would lose a little bit of suction due to reducing the size of the lines.
mrm95
Oct 16, 2014 06:39 PM
David Buschur
Aug 12, 2012 07:39 PM
snafufx
Jul 21, 2012 12:06 AM
3gEclipseTurbo
Dec 5, 2010 10:45 AM
David Buschur
Nov 23, 2010 05:57 PM
