GTX3582R Or Pt6262
The AQ Motorsports STI made good power with the GTX3582:
http://www.motoiq.com/magazine_artic...x-upgrade.aspx
And the GST Impreza Time Attack car, which I think is the fastest AWD time attack car in the US, is using the GTX3582.
will water cooling the turbo and and wastegate benefit the cars performance at all if the car is not going to be Road Raced. It will only be used for Drag/Street so I dont know if i will be able to benefit from this option.
Also Is the turbo lag going to be the same with both turbos or is there one that is slightly faster? An as overall numbers go do you think one of these turbos will be able to achieve better numbers?
I personally like water cooling because it is beneficial, but its not necessary. The previous version 6262 used a turbine that was less efficient and slower spooling than the 35R UHP turbine, but PTE has now updated their design. With this update, I cant give a solid answer on which will spool quicker or make more power.
Moore auto just posted my first dyno plot on my build thread, i made 500/420 with plenty of room to grow, my O2 housing is a ebay knock off and is restricting flow. https://www.evolutionm.net/forums/al...-thread-4.html
evoxisking
Oct 18, 2015 03:37 PM
ETS Michael
86
Jan 8, 2013 02:48 PM
