Whos running a Walbro 400LPH FP?
im running the walbro 400lph pump in my evo 8, using stock wiring, stock fuel rail, stock FPR and stock lines. No problems so far but ive only driven 14 miles total doing shakedowns
edit: going to tune tomorrow on pump gas (crappy az 91 octane) and see what it does, ill post up in this thread after
Use the Walbro 400. The fuel pump hanger modifications are a 30 minute job, or you can send your hanger to Buschur or MAP & they will install the 400 for approx. $100 in labor.
I ran out of fuel with the Walbro 255 on E-85 and 1450cc FIC Bluemax Injectors. 525HP/424TQ on VD (Dynojet Setting).
I installed a Walbro 400 and an adjustable FPR, probably didn't need the FPR. The tune richened up significantly, but I have not been re-tuned for the 400 yet. I'm going to have Tom tune it on the standard wiring, no rewire.
I'm guessing that an adjustable FPR isn't necessary on the stock wiring, but you will probably need one if you do a rewire.
i definitely plan on getting this fuel pump. im really considering doing my own install...but im kinda waiting on a side by side comparison picture of a stock/walbro 255 setup vs the walbro 400 housing...if anyone can provide the pics of the housings side by side that would be a great help to this thread!
from what im reading, this pump should be capable of 600whp on e85. not sure about the re-wire though...i think when i am gonna install it ill just keep it on stock wiring.
but im lost as to whether we REALLY need to run an adjustable FPR with this fuel pump.
