My Evo 9 MR Kinugawa 25g install - photos
I've been running this turbo for the last 4 months,i had a little problem with the wastegate which they fixed right away,i can post my VD sheet if you want,i don't want to just post my own results on your thread without your consent,overall i'm well pleased with the results considering the price i paid.It's a very good option to the other turbos out there,if you tune yourself i can email you my tune so you can have a good starting point tune wise.Good luck
Mod list at the time: completly stock 2.0 block,HKS 272 cams,Vishnu cam gears,Injen piping kit,ETS 4" fmic,self built cop kit,Prosport gauges,Forge unos mbc,Forge Type RS 50mm blow off,HKS air filter,Walbro 255 in tank,ACT HD clutch with 6 puck sprung hub disc,Swift Spec R springs,O.Z. ultrallegera 18x9,Zeitronix ZT2 WB,Kinugawa 25G,self ported stock exhaust manifold,ARP head studs,Gates racing timing belts,Blox front engine mount,OBX front LSD,Megan O2 housing,Magnaflow 3" tbe,1200 cc PTE injectors,self tuned on SD and Tephra V7.
With a little more time to tune i know i could have gotten it in the 450s,i was able to get this turbo to spool only 350 rpms later than my Evo 9 turbo ,with better cams i know it would be even better,and this thing would be crazy on E85,i didn't have time to do any more testing since my 3 year old Walbro failed on a high boost run and destroyed my engine,now i'm in the middle of building my fully built 2.4 LR,imo this is a great turbo for the money with enough power potential to have some good fun
If you want the tune i can email it to you no problem,i can also adjust it for SD or MAF or different injectors,just let me know.
Compressor wheel: 57.76/78.05mm (measured at very tips of blades which I think dive in slightly on the inducer)
Turbine wheel: 53.60/60.89mm
Please refer back to my picture folder here for photo's of the measurements:
https://plus.google.com/u/0/photos/1...15120451571953
Compressor is a 5 blade and turbine is an 11 blade.
I would say the posted numbers from authentic boosting would be accurate given my caliper or eyes could be off.
Check this out, billet 6 blade upgrade for the 25g:
http://shopping.kinugawaturbo.com/tu...hks3037-1.aspx
Yes sir they do,but you have to machine the center housing (cartridge) to accept the bigger blade,i did the math and called a few places and the price of the parts and machining came out to close what a brand new 25G goes for and you still keep the factory turbine blade instead of upgrading to the TD06SL2R,and i sold my evo 9 turbo so it was a no brainer for me but is also a good choice
Hey man just to add some info on here I actually just took on the task of converting my 9 turbo to this 25g in order to fit the compressor wheel you will need to machine the center section as stated its simple lathe work and ran me 70$ at a local shop I think found my turbine was cracked and replaced it w the upgraded td06sl2 as the assembled turbo includes which led me to need to either have my Hotside machined or buy a Hotside to fit this wheel I opted w option two as it was about the same price so this is all great info long story short if you want to retain the stock td05 turbine and upgrade to the 25g wheel it's cost effective if you want the upgraded turbine as well it will run you similar pricing as buying the piece new! No testing has been done on mine yet but it's going on a 2.4 so should be interesting... Also w reference to the oil feed question it has a performance thrust bearing set in w two oiling holes so I opted w the line off oil filter housing w fp filter and restrictor for journal bearing turbos
