Power drops when upshifting...
Old Mar 18, 2012 | 02:41 AM
jameswwt's Avatar
Hi,
can anyone share on how to improve or maintain the power/response when upshifting?
Can we adjust on the timing map and which rpm/load should we adjust?
Thanks
Old Mar 23, 2012 | 12:34 PM
escodotcarter's Avatar
ball bearing turbo
Old Mar 23, 2012 | 09:16 PM
RSMike's Avatar
if your accelerator pumps are not adding enough fuel, it will feel very laggy inbetween shifts.
check those settings and try again.
Old Mar 25, 2012 | 09:15 AM
jameswwt's Avatar
Tqvm RSMike...Ive a 340L Aeromotive fuel pump
Old Mar 25, 2012 | 11:31 AM
RSMike's Avatar
accelerator pumps are a setting in the ECU.
When you have a large change in TPS (e.g. when you floor it) you have to add extra fuel to get instant power.
If there is not extra fuel being added, it will add considerable lag.
e.g. you press on the throttle, and it will take 0.5 to 1.0 seconds to actually start to go.
If you're tuned to approx 12:1 AFR, when you floor it the fuel should momentarily go to approx 10.5:1 then back to 12:1
Old Mar 26, 2012 | 03:08 AM
jameswwt's Avatar
Hi Mikey...yes, this is the problem which ive been trying to get the world know!
My car really response badly as whenever i full throttle (floor) my car just deep (afr deep til 10.5 and goes back to 13) and it seems have been added few hundred kilos of weight. Its just hard to catapult until ive to partial lift off and throttle again and again only than my car catapult!
Mind to advise me how to set the "Accelerator pumps setting" on my PFC ecu?
Lastly, will an incorrect injector scaling have a big effect on the entire response/tune performance?
Please
Old Mar 26, 2012 | 11:36 AM
RSMike's Avatar
I'm not sure sorry James, you'll have to take it to your tuner!
Old Mar 26, 2012 | 05:43 PM
jameswwt's Avatar
Its ok Mike as i plan to tweak the tune myself.
Old Mar 26, 2012 | 10:09 PM
dastallion951's Avatar
not to chime in but uve been havin a lot of issues with your evo, through previous threads, not to question your abilities, but in your case I would have a remote tune done through a vendor here, all you need is a laptop and tactrix cable, my guess your fuel trims arent right, which throws your tune off. Especially if you say if you floor it and it hits 10.5 then goes up to 13.0 if its going 13.0 in higher rpms thats dangerous lean. So something fuel related isnt right, thus the brick wall feeling and excessive laggyness. Trust me a properly tuned car should pull hard through the whole rpm range.
Good luck hope it helps.
Old Mar 27, 2012 | 07:04 AM
Ang Wen Yan's Avatar
He is using Power FC so remote tune is not an option
Old Mar 27, 2012 | 08:15 AM
boosted91t's Avatar
I see that you are on PFC, but no lift to shift is one answer
Old Mar 27, 2012 | 09:23 AM
then ang wen his best bet is to go to a shop that has a dyno n is capable of tuning the power fc, or getting in touch with apexi, and have him tune the car, or give him some pointers, because from what hes sayin earlier, his midrange is going fat rich, and then going lean in higher rpms, definitely not good, his engines not liking that, and these engines while good, are very temper mental.
Old Mar 27, 2012 | 09:45 AM
gkania's Avatar
Get rid of that powerfc. Its about 10 year old technology.
DSPORT
Oct 19, 2015 11:33 AM
HunterSwift
Mitsubishi TC-SST Discussion
49
Apr 25, 2014 08:30 PM
Evorange
Feb 11, 2013 04:33 AM
AK805
Lancer Engine Tech
27
Dec 10, 2007 07:58 PM
93civEJ1
58
Apr 14, 2005 04:17 PM
