boost surge??
Old Mar 21, 2012 | 03:11 PM
kanovic's Avatar
Boost surge??
Hey guys I have a 06 mr and lately when I'm driving it and get on it the boost will surge. For example it will go to 14psi then down to 12psi then back to normal again. Seems to be worst when going up a incline and only when at wot. I'm guessing it's a boost leak but being my first turbo car i wanna see what u guys say.. I'm in the process of making a adapter to do a boost leak test. Any info appreciated thanks.
Old Mar 21, 2012 | 09:41 PM
sparky's Avatar
So, I am curious as to what the peak or highest boost level has been until now that you are experiencing this boost oscillation.
Old Mar 21, 2012 | 09:56 PM
sparky's Avatar
You didn't post the same thread on two subforums did you? Or did you even post it on more than two....you sneaky devil?
Old Mar 22, 2012 | 04:07 AM
kanovic's Avatar
It tuned at 18psi and It will spike to about 19 highest iv ever seen it.
Old Mar 22, 2012 | 04:07 PM
ProPilot04's Avatar
1. Welcome.
2. I would start with a boost leak test.
Old Mar 22, 2012 | 04:16 PM
Kracka's Avatar
14-12-14 is not surge.
Old Mar 22, 2012 | 04:19 PM
Kracka's Avatar
Merged. You get one thread.
Old Mar 22, 2012 | 05:16 PM
kanovic's Avatar
its feels like it though, you can feel the car when it looses the pressure but it will do it only sometimes and you can feel it rocking back and forth as well as hear the turbo change the ton.
Old Mar 22, 2012 | 10:45 PM
sparky's Avatar
You didn't post up your modlist. With boost issues it is best to know at least what type of boost control you are using. Should we assume that your car is mostly stock? Also, are you using the stock diverter valve or not. What gear were you noticing the boost oscillation in?
Everything is stock, right? Or, is it not?
Old Mar 23, 2012 | 04:43 AM
kanovic's Avatar
Sorry I should have known better. But the mod list injen uicp licp, 3"fmic,1250fic injectors,255walbro, kelford 272cams,greedy bov, 3"exhaust no cats or anything,aem truboost. It's timed at 18psi currently and the most noticeable gear I notice it at is 3rd and up but it doesn't always do it. Some days u can get on it and it holds steady throughout the gears.
Old Mar 28, 2012 | 08:44 PM
repairmanevo8's Avatar
subscribed. I'm having the same issue.
supwiddiss
Sep 20, 2017 01:55 AM
Tbtalon94
86
Sep 24, 2010 12:45 PM
omniprobe
11
Jul 13, 2010 03:23 AM
house_of_senate
12
Sep 21, 2009 06:29 AM
th3_rEv8lution
Feb 14, 2008 10:53 AM
