Quarter Marter harmonics problem/fix
Old Mar 27, 2012 | 03:15 PM
  #31
R/TErnie's Avatar
yes you would still get the good high RPM shift because the input shaft only spins the 7.25" diameter discs and drive hub when you're shifting... less inertia for the synchronizers to clutch.
Old Mar 27, 2012 | 03:42 PM
  #32
droppinbottom's Avatar
Originally Posted by evodan2004
my clutch is ordered thanks to a buddy of mine , we ordered the race clutch. but because i drive the car on the street and i try to race it hard at the track would it be wise for me to buy the QM street flywheel ''being a bit heavier'' and putting the RACE clutch on it??? would i still get the good high RPM shift?
So far I've shifted at about 8200 and the shifts are extremely smooth. I still have to be careful not to engage the clutch too quickly as it grabs so hard I am afraid it could eventualy cause druveline damage. If I had to do it all over again I would of probably gone with the street disk but since I have not driven a street disk it is just a guess.
The one thing I'm starting to notice is that after driving in traffic for a while it seems to be more difficult to take off from a light. The clutch is easier to slip while cold but once warm it can be a challenge to slip it and pull away from a light smoothly.
Old Mar 27, 2012 | 05:52 PM
  #33
PATRICK B.'s Avatar
That makes sense as the disc material heats up so does the friction causing it to grab quicker, harder, faster..........until you put too much heat to it
I'm in the same boat if the auto stuff isn't ready soone than later as i have the original QM and have contemplated going to the V2 if the Evo remains a 5 spd.
This heavier FW looks like a nice option for some but still never going to be that "magic" clutch that can do it all
Old Mar 27, 2012 | 06:44 PM
  #34
gctech's Avatar
Originally Posted by R/TErnie
I can say with certainty that these are not the same clutches.
a 7.25" clutch is quite common and a lot of the parts are interchangeable due to their use in racing.
A LOT of people make a 7.25" clutch, but I wouldn't confuse QM with SPEC.
I respecfully disagree I have both and interchaged the parts with out any issue 100% bolt on like I said the only diference is the cover and the flywheel design
jakub
For Sale - Wheels / Tires
15
Mar 3, 2016 09:38 PM
evodude32
259
Aug 26, 2015 09:22 PM
Mid_Evo
Dec 22, 2013 09:46 PM
atcmac3
For Sale - Cars For Sale
Oct 14, 2012 05:42 PM
WickedIXMR
13
Apr 30, 2009 01:16 PM
