EVO 1 to 9 Rear LSD questions
Old Apr 28, 2012 | 03:12 PM
Glycerine's Avatar
launching not very often..
2 have broken due to a launch,
2 broke under mild/normal acceleration.
Old May 14, 2012 | 07:28 PM
burnzy's Avatar
will this work for evo 6 too?
Old May 14, 2012 | 11:33 PM
Glycerine's Avatar
Yes it will but you need to find a open diff & shafts that will bolt into you car.
And then just pull the ayc pump and lines out, and unplug or remove the ayc ecu
Old May 15, 2012 | 12:41 PM
GregM's Avatar
Just sourcing parts for my Evo 5 to do the LSD swap as well.
Old May 15, 2012 | 03:39 PM
WRC-LVR's Avatar
Beautiful car....sure wish they had imported them to the USA....
Is that an automatic BTW?
GLW the build
Old May 15, 2012 | 08:08 PM
Glycerine's Avatar
Nope, its a 5 speed manual, W5M
pretty much the same box as the evo's get, slightly different ratio gears,
and a longer final drive, all parts interchange apart from the bell housing.
Old Jul 14, 2012 | 10:17 PM
GregM's Avatar
Just checked the Lancer GSR diff, axles and mounts I bought to fit to my Evo 5 to find the diff has an LSD already in it. The GSR must have had the option of an LSD and I just got lucky. Not a bad buy for NZ$500 for everything
jasmineee
Evo X How Tos / Installations
Feb 7, 2017 06:10 AM
DSPORT
Aug 26, 2015 12:24 PM
MikeColangelo
May 25, 2009 03:06 AM
Jeffs2006EVOIX
Sep 22, 2006 04:22 PM
