budget evo 4 5 6 radiator!
Stocks rads really seem capable of handling what many/most owner can throw at them.
Maybe their luck wasn't so great but I know two owners that had their circuit 4 and 5 go back to using stock units because they had over heating issues with high priced full aluminium units.
Yes I did buy the evo 4-6 radiator from Ebay but it was too thick and my 6466 turbo was hitting it. That's why I was needing a thinner but full radiator. My half civic radiator is fine if I'm running normal. But as soon as I run WOT for a long period of time back -to -back racing on highway, then it would heat up almost to the top on my water temp gauge inside.
I have been running the KOYO Mirage radiator since March of 2013. My car is a daily driver with AC and I have not experienced cooling issues. I run the stock PS pusher fan and a 14" puller fan on the DS wired through the factory DS fan controller. Never see temperatures above 180F even in the middle of summer with AC on and sitting still. I have no experience with this radiator for racing applications. I had to make my own custom top brackets from aluminum using the inserts from the stock mount. On the bottom it fits the factory mounts, but I added ~0.200" spacers to slightly raise the radiator, which is not necessary. I can provide the part number for the hose I used if anyone is interested.
n2oiroc
11
May 10, 2017 07:23 PM
n2oiroc
Aug 27, 2016 03:12 PM
n2oiroc
Jul 22, 2016 09:04 PM
n2oiroc
Jul 17, 2016 11:29 PM
