Fluidampr Install
Old Apr 10, 2012 | 05:08 PM
fastyouth1313's Avatar
Fluidampr Install
hey guys!
Im looking at buying a used fluidampr for my evo 8 (the steel one) i have been searching for an evo install guide or something of the sorts and have only came across a DSM install. is it just the four bolts? just bolt it on and am good? should i be worried that it is used? its in good condition but it has been installed and ran already.
thanx for you help!
Old Apr 10, 2012 | 05:11 PM
AWDs's Avatar
It's the same process as any other Harmonic Balancer...As far as used goes, I would personally buy one new as something like that is important, but thats me.
Old Apr 10, 2012 | 05:13 PM
when you say its the same as any other harmonic balancer, what do you mean? i have read the install instruction and its not vehicle specific. i just see the 4 bolts???
Old Apr 10, 2012 | 05:22 PM
AWDs's Avatar
Thats all it is is the four bolts.
Old Apr 10, 2012 | 06:21 PM
the crank wont spin when i try and take the pulley off? is there any tricks to keeping the crank from turning?
Old Apr 10, 2012 | 06:24 PM
Blue Evo 8's Avatar
4 small bolts, torque to 20 ft/bs
Old Apr 10, 2012 | 06:25 PM
can i put loctite on the bolts when i re-install the new pulley?
Old Apr 10, 2012 | 06:38 PM
LCS's Avatar
LCS
The torque for the four bolts is so low - 25Nm - the crank won´t spin easily.
Old Apr 10, 2012 | 06:39 PM
where did you get your torque values? i have serached for a service manual but can find a legit one.
you have a link to a download?
Old Apr 10, 2012 | 06:43 PM
thanx for your input!! do you have a link to anywhere to get a service manual?
Old Apr 10, 2012 | 07:14 PM
Blue Evo 8's Avatar
I have the Fluidampr, the older aluminum model, and the instructions specified 20 ft lbs.
Old Apr 11, 2012 | 12:36 PM
okevolutionVIII's Avatar
The Fluidampr has its own recommended torque values. As far as a service manual, I bought one in disc form off eBay and you can save the manual on your computer/laptop and read it with Adobe.
Old Apr 23, 2018 | 12:04 PM
2rbolag's Avatar
So what are the torque numbers when installing the fluidampr? Some say 20lb/tq others 25. I went to their website but didn’t find any info for the evo 8/9 application
Old Apr 23, 2018 | 03:02 PM
barneyb's Avatar
FSM says 19 plus or minus 2 ft lbs. 19 plus or minus 2 and 20 - pretty much the same thing.
Old Apr 23, 2018 | 04:02 PM
LetsGetThisDone's Avatar
Those bolts like to come lose at factory spec. 25flbs, with red loctite.
fugiwara
23
Sep 16, 2016 05:36 PM
SnailBums
Feb 20, 2016 07:52 AM
OverBoostedEvo
Aug 25, 2015 09:38 AM
EDDIE12
18
Aug 10, 2015 02:16 PM
chamelieon
12
Jan 31, 2014 11:53 AM
