INSTALLED: Greddy TBE
I went to take it to get a troubleshoot test
it says.. catalyst efficiency below threshold, or faulty catalytic converter, or exhaust near ho2 sensor.
Can an exhaust leak really give a check light??
The CEL is because you have no catalytic converter on your new exhaust causing your O2 sensor to read wrong and trip the CEL light.. it wont pass emissions tests if your in that type of state.
nvm i found it but it does not say anything specific on what type of exhuast and where would this part go?
http://www.speedelement.com/index.ph...emart&Itemid=1
The picture of the exhaust laying on the ground. It looks like it has a resonated test pipe, no cat. I could be wrong. Google search pictures of cats and see what they look like.
i think it is a high flow cat..
im thinking of trying to just use an 02 spacer.
my questions is will i have to drill bit this spacer like the spark plug fouler's???
http://www.amsperformance.com/cart/A...or-Spacer.html
LCS
Sep 14, 2011 04:58 PM
outsider
27
May 24, 2006 05:36 PM
SubiEvolved
Aug 22, 2004 08:14 PM
