Any ideas why im not boosting?
Old Jul 4, 2012 | 08:29 AM
sparky's Avatar
I would say that you should try raising preload to about 23-24 PSI for your 27# peak. You know how to do this correct?
Old Jul 4, 2012 | 08:31 AM
fastyouth1313's Avatar
Yea I know how to add more Pre load. Boost spiked and held at 20 psi. I understand I snuck out of bed early to go figure this out cause all day yesterday I was messing with it.
Old Jul 4, 2012 | 08:32 AM
Evoardo IX's Avatar
Originally Posted by sparky
Eduardo, yours is a Latin American Market RS isn't it? I have a Latin American Market VIII RS which originally came with a JDM Ti wheel VIII RS turbo. If your IX came with a TiAl wheeled JDM turbo then I would say that you should be seeing 27 PSI by 3200-3400 RPM once spring pressure is optimized.
Yup, is a JDM RS, but I don't have that Ti turbo, I have the TD05HR-16G6C-10.5T which I believe is Al - Inconel only, am I correct?
What can be the reason for such a late spool?
Old Jul 4, 2012 | 08:38 AM
Evoardo IX's Avatar
I am on vacation in Antigua, Guatemala today. The family is dragging me out the door to go visit a pagan religious shrine. So, I'll check back in about three hours. Sorry, duty calls. I am sure that you will understand.
Yeah we understand, but don't take too long jk man, have fun, hopefully we'll continue with the tech talk and thanks for your help!
Old Jul 4, 2012 | 09:03 AM
I have to wait for everything to cool before I stick my hands back in there
Old Jul 4, 2012 | 09:10 AM
Evoardo IX's Avatar
You're lucky, I have to wait a couple of days before I go back to my car
Keep us posted with results, I will try the preload thing based on your results
Old Jul 4, 2012 | 09:36 AM
Here in a bit I'll go tighten then do another pull. With that mishimoto rad it's a tight fit plus it's extra hot!
Old Jul 4, 2012 | 09:38 AM
Evoardo IX's Avatar
I was looking down there the other day and I was thinking I should remove the rad, but now that you mention it I guess it can be done without removing... Did you have the stock heatshield in place? is it hard to remove?
Old Jul 4, 2012 | 10:01 AM
No removed the heats shields. The mani heat shield is easy but the o2 housing heat shield is tough! But I have an o2 dump now. You don't have to remove the rad but you have to be really careful not to poke a hole in the stock rad cause it's super brittle!
Old Jul 4, 2012 | 10:29 AM
Going to do pull now. My actuator is arm is fully tightened.
Old Jul 4, 2012 | 10:37 AM
Same results as before... I have the 18# spring in there. Should i input the 25# spring in there???
Old Jul 4, 2012 | 10:39 AM
Craig King's Avatar
You are probably low on turbo fluid.
Old Jul 4, 2012 | 10:57 AM
Evoardo IX's Avatar
Wow
Old Jul 4, 2012 | 10:58 AM
Evoardo IX's Avatar
Since you have the option I say go ahead and try that.... I was thinking it could also be the o2 dump you installed, maybe it's not letting the wastegate flapper seal properly inside...
Old Jul 4, 2012 | 11:00 AM
Nope I checked it and it's full
