motor mount bolt size?
Old Jul 27, 2012 | 03:38 PM
89turbosupra's Avatar
Ok guys so i started the process of taking out my transfer case today and to my suprise when i removed the splash guards the bolt for the motor mount that is located on the crossmember (thr one running from the front to the back of the car) was missing. I have no idea how it could have came loose or even how long its been missing but regardless it needs to be replaced. So if anyone would happen to know the dimensions of this particular bolt id appreciate it.
Old Jul 27, 2012 | 04:37 PM
CurseDSM's Avatar
it would be pnc 02886b, part# mf140273, part spec flange, 10x75
Old Jul 27, 2012 | 06:42 PM
Thanks!
Old Oct 14, 2012 | 12:42 PM
uvambo's Avatar
is the bolt sposed to be alot smaller than the sleave size within the motor mount? like just looking at mine my bolt is about 3/8 and sleave ID is about 1/2" i would think they should fit perfectly?? anyone know
Old Oct 17, 2012 | 07:18 PM
masonh's Avatar
i think the bolt is right around .400" and the hole is right around .500".i wondered the same thing.one would think the bolt should be just a hair smaller than the hole for the best performance,but it's not.
i was thinking about drilling the mount out to 1/2" or sleeving the bolt with aluminum or phenolic.the drilling will probably be the best,but the mount in the rear is aluinum and i wasn't keen on the idea of drilling the aluminum hole bigger.
Emmy
Nov 3, 2016 02:51 PM
dragon831
Nov 30, 2015 06:18 AM
rogue
32
Dec 10, 2014 06:37 AM
02ES=>09RAL
Nov 2, 2014 06:50 PM
erikm-x
Mar 27, 2012 02:04 PM
