DV recomendation for 22-25 psi ?
Old Aug 27, 2012 | 06:53 AM
stunt2's Avatar
Question DV recomendation for 22-25 psi ?
hey guys, need suggestions which diverter valve to get to hold 22-25 psi pressure with no leaks. don't want VTA any more, mostly thinking about fully recirculated or maby some hybrid type too that has adjustment for venting/diverting.
lower price is also important. currently thinking about stock metal dv or GFB stealh(deceptor) one but would like to hear any other suggestions too
Old Aug 27, 2012 | 07:20 AM
Swaggers's Avatar
Veteran: Army
I heard a Stock IX DV was pretty decent. You can get one for a reasonable price from a forum member I'm sure.
Old Aug 27, 2012 | 07:27 AM
boosted91t's Avatar
Stock IX, aps twin, synapse dv
Old Aug 27, 2012 | 07:44 AM
mrfred's Avatar
+1 except the aps twin vent is no longer made. the cobb xle dv is a great alternative.
Old Aug 27, 2012 | 08:48 AM
Thore's Avatar
A regular IX DV has treated me pretty well for the most part. Holds 25psi no problem with minimal fluttering in 5th.
Other than that, I would personally go with a Synapse DV
Old Aug 27, 2012 | 10:02 AM
thepoint4life23's Avatar
Just Crush a ix dv and it will hold the boost you want to run.
Old Aug 27, 2012 | 10:27 AM
stunt2's Avatar
is there any difference between 8MR, IX and X valves ? spring pressure or something
Old Aug 27, 2012 | 11:52 AM
8 were plastic
Old Aug 27, 2012 | 11:55 AM
Evo Tengoku's Avatar
WORKS DV, uses the factory piece but with a stronger spring in it.
Old Aug 27, 2012 | 03:25 PM
ball7068's Avatar
My stock IX DV is holding 29psi just fine... and I probably will not replace it until I upgrade the turbo. So that's my recommendation...
Old Aug 28, 2012 | 08:42 AM
stunt2's Avatar
so I'll probably get oem metal DV from someone out here
is it safe to buy it used, or does the mileage matter ? are they tend to leak over time ? don't want to get leaky one
