Ticking sound, mostly when cold
Old Sep 14, 2012 | 07:32 PM
mikespike2's Avatar
Hey guys, my car has had a ticking sound for quite a while now. Started around 20k miles, has 40k now. Almost always goes away once it is up to temp.
I did try to pull the idler pulley off and the bolt head hits the frame rail before it comes all the way out... any ideas there?
Also checked with my ear and a screwdrive above and below and it sounds like it is in the belt area. I made sure it isn't in the oil pan or valve cover area when I first heard it.
What do you think it is?
As far as troubleshooting, should I pull the serpentine belt and start the engine to see if it is gone?
Thanks
Short video:
Old Sep 14, 2012 | 07:40 PM
detroit pistins's Avatar
https://www.evolutionm.net/forums/ev...elt-video.html
Old Sep 14, 2012 | 07:45 PM
mikespike2's Avatar
Originally Posted by detroit pistins
So it is common.
I have been waiting for it to get worse or seize so I can figure out what it is, but it sure is consistent.
A lot of people saying it is the crank pulley. I find that hard to believe unless everyone has crank pulley bolts coming loose
I still think serpentine idler or timing belt idler.
Old Sep 14, 2012 | 07:49 PM
try page #42, it has some good details.
Originally Posted by Positron
My friends repair shop did my 60k service today with the new bracket. No more weird idle noise and etc. I ordered the new bracket from Mitsubishiparts.net the other week. The bracket install took a hour longer because the power steering unit needed to come loose and what not.
I took some pictures of new bracket and old oem bracket.
left is NEW, right is OLD
NEW
OLD
Old Sep 14, 2012 | 07:59 PM
mikespike2's Avatar
Thanks... was on page 15 when I came back and saw your reply. They look pretty similar. Some people saying it was incorrectly machined. Wish I knew the exact difference so I could just machine it to the updated version.
Looking further back for the P/N and a site to buy from. Should only have to replace the bracket and re-use the other parts?
Edit: P/N's and cost from mitsubishiparts.net.
MR984375 Adjuster, Timing Belt Tension Qty 1 $112.17
MD369999 Pulley, Timing Belt Tension Qty 1 $32.01
1091A133 Bracket Cylinder Block Qty 1 $129 *Updated New Part from Mitsubishi
1145A038 Belt, Valve Timing Qty 1 $67.65
MR984778 Belt, Balancer Timing Qty 1 $24.50
silverevo05
20
Oct 10, 2020 08:58 AM
Michael Cain
Nov 12, 2016 10:20 AM
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
Blue04ES
Lancer Troubleshooting
Oct 6, 2010 05:02 PM
Sakamara
12
Mar 1, 2010 04:04 PM
