The Perfect fuel and system at 700 awhp
Old Sep 15, 2012 | 01:48 AM
jrblackSE's Avatar
Hello everyone! as my 9 project is coming to completion im getting very curious on what i am going to need to hit to 700 mark in the future on either e85 or e98. I am currently running 2 Aeromotive 340's in a FB Double Hanger with -8 feed and -6 return with e98 achieving 674/516 at 33 psi on a Carrilo rotating 2.3l HTA 86. The modifications are capable I am just curious if i should stick with the e98 and get an ETS 4"IC and 3" UICP or if all I really need is a sweet surge tank and a couple more bosch pumps! Any input is appreciated!
THANKS IN ADVANCE!
Justin Reaves
jrblackSE
Old Sep 15, 2012 | 09:48 AM
thepoint4life23's Avatar
It sounds like your Fuel Set up should get the job done
Old Sep 15, 2012 | 10:19 AM
GTijoejoe's Avatar
.... yeah I think you're supply setup is set dude.... you just didn't mention your rail and injectors though
Old Sep 15, 2012 | 10:38 AM
psphinx81's Avatar
i made 700whp on a mustang dyno with just a BR double pumper, BR fuel rail, FIC 2150's on E85, stock lines
Old Sep 15, 2012 | 11:12 AM
cmn130's Avatar
E85 bigger fuel pump and injectors.
Old Sep 15, 2012 | 12:04 PM
tscompusa's Avatar
run into cars time and time again.. people try to go all out overkill on evos when its not necessary..
a buschur double pumper and fic 2150cc is all you will ever need for 99% of people. you can use the stock FPR forever on a double pumper because its only using the 1 fuel pump until around 8psi is produced. theres no reason to rewire either in a evo.. theres a high and low relay that kicks on and off during driving so the pumps don't get overrun with stock fpr.
The stock rail goes a long way also, but i have a AMS rail on my car now.. but any good rail will work well.
the injectors may be a bit overkill, but they work well.. extremely awesome injectors.. for both 93 and e85.
run out of fuel with a br double pump and 2150's ? then make your feedline -6 and you will be good for 850whp..
i think the combo i mentioned is good for around 950whp once you have the feedline and return diameter to cover the fueling needed.. the stock lines are only 5/16"off the top of my head.. they are bottlenecked around 750whp i believe off the top of my head.
all the above is assuming you're running e85.
Old Sep 15, 2012 | 05:32 PM
domestickillaAR's Avatar
Personally i HATE haven to buy **** over n over again so when i build my car i try to plan to do it once and given myself room to grow if need be, like i said why waste money redoing things.
ill be running a MagnaFuel 750 external fuel pump i heard they are good for well over 1k whp and have low power draw and quiet operation. I originally was going to use a FuLLBlown dual hanger also but after everyone ive talked to who ran one hated them. said they leaked like crazy n could never get them to seal correctly due to the epoxy they use breaks down esp when running E-85/E-98
Im going to be running -8 feed and returns also along with 2150cc FIC injectors and a FIC fuel rail. I bought a fuel Lab mini regulator and metal fuel lab filter assembly since like yourself ill be on e-85/e-98 also. Im sure i fall into the going overkill but oh well lol
Old Sep 15, 2012 | 06:30 PM
n2oiroc's Avatar
depends what you are doing. street and drag on just one fuel type, double pumper is fine. road course or swap between pump and e85? surge tank and a pair of 044's.
jrblackSE
Sep 13, 2014 07:44 PM
jrblackSE
For Sale - Cars For Sale
Jul 8, 2013 03:12 PM
jrblackSE
Member Unresolved Disputes
21
Sep 26, 2012 05:49 AM
jrblackSE
26
Aug 30, 2012 11:02 PM
jrblackSE
Jul 13, 2012 12:07 PM
