Will there be any harm by running 100% water without Meth?
Old Oct 1, 2012 | 10:36 AM
jameswwt's Avatar
Ive just installed the AEM Water/Meth kit today and have put in some mineral water for the pump/spray test as ive not buy the Meth.
So my concern is will it be dangerous by temporary running 100% water into the engine without methanol?
Thanks
Old Oct 1, 2012 | 11:17 AM
Davo's Avatar
You would just be cooling the intake charge and not increasing octane levels
Old Oct 1, 2012 | 11:29 AM
Dallas J's Avatar
Veteran: Army
Water injection probably came before meth injection and technically speaking water injection is legal for SCCA solo but not methanol.
Back in 06ish when I was running meth I would use the coldest rated windshield washer fluid I could find. I think it was the -20 or -30 stuff that was like 49.9% water, 49.9% alcohol, and .2% blue dye.
Old Oct 1, 2012 | 11:49 AM
mt057's Avatar
If you are spraying water you want to use distilled and only spray a little. It is not compressible and to much will cause serious issues. Think about 5% fuel replacement or addition.
Make sure to use small jets as well to help fully atomize. It has more surface tension than methanol.
I would just wait for the methanol. Changing up the system and tune around would be a pain.
Old Oct 2, 2012 | 01:43 AM
jameswwt's Avatar
Thank you Guys...
Old Oct 2, 2012 | 09:02 AM
Ted B's Avatar
That makes good common sense. In actuality however, a factory ignition system will start misfiring before one can damage the engine from water vapor. This is how WRC cars generate 500+ft/lbs with a tiny turbo and 98 RON.
For example, I run straight H2O with a 15gph (M15) nozzle and 150psi Shurflow pump, which is somewhere between 1000+cc/min water above 25psi, which is 25-30% of the total fuel charge at peak hp.
Old Oct 2, 2012 | 09:10 AM
jameswwt's Avatar
Thanks for the info TedB.
The improved torque & power is immediate even thou im using 100% at the moment...
Will make some pulls & check knock tmr afternoon...Hope even with water it can suppress knock.
My Meth will be deliver in a day or two...
Old Oct 2, 2012 | 09:31 AM
EvocentriK's Avatar
So the water alone cools the intake charge which has been heated to v.high temps from high boost with small turbo?
Old Oct 2, 2012 | 10:57 AM
mt057's Avatar
Wow...that is a lot of H2O. That is the most I have ever heard of someone spraying.
I see what you are saying. I never fully thought about the water vapor preventing the ignition event before possibly causing damage.
I guess in order for it to cause an issue the pump would have to be stuck on full flow. That would cause problems no matter what your spraying.
Thank you for posting up the good info. Always nice to learn something new.
Old Oct 2, 2012 | 12:35 PM
JohnBradley's Avatar
Your intake temps will need to be over 140 for it to vaporise correctly. Otherwise you will end up needing to run the AFRS fairly lean to make it work.
Old Oct 3, 2012 | 05:06 AM
jameswwt's Avatar
Dont i wish ive run water/meth much earlier...Less knock, smoother engine & better response even with just water spray at the moment.
But ive 2 problems which is my car seem slightly harder to start during cranking & the idle goes 300rpm more as my usual idle rpm is 1,000rpm but now it goes up to 1,300~1,400rpm?
1) Should i adjust on Cranking Primer - First Pulse?
2) Will it be some vacumn leak which caused the idle rpm to goes up? But boost hold great.
Old Oct 3, 2012 | 06:54 PM
jameswwt's Avatar
Any advise?
Thanks
me-var
Oct 25, 2015 02:21 PM
kevness
Oct 2, 2013 04:07 PM
cij911
29
Feb 23, 2009 03:50 PM
Sti THIS
28
Aug 2, 2007 08:29 AM
