What mod to do next? opinions please....
Old Oct 11, 2012 | 08:15 PM
IAmADirtDude's Avatar
so ive done everything up to fmic, cams, 750 injectors, all mods in signature.... next i was thinking either ethenol maping which costs the map and the 1000-1200cc injectors or a green turbo....
now i already need a new tune for my gas map as it was old and needed to be changed for smog to pass and the clutch was slipping so i couldnt put it on the dyno to pass smog. so my costs are already a tune on gas, and a new boost solenoid to the updated style since i was using the old aem tru boost style. so on top of that i will be doing either a turbo or a ethenol map with injectors unless there are any other mods someone can think of.
im very mechanically inclined and was thinking maybe i should use my diamond bit on my die grinder to port my own intake manifold i also dont know if this is a good idea...
any help is good thanks
Old Oct 11, 2012 | 11:34 PM
dkslvr06evo's Avatar
I would get as much as you can out of the stock turbo by upgrading the injectors and a tune. Then later on you will have the fuel needed for the larger turbo.
Old Oct 12, 2012 | 06:26 PM
Spoolin63's Avatar
Injectors, good quality wastegate, e85 and a tune. Just my opinion tho.
Old Oct 25, 2012 | 04:17 PM
Cloud85's Avatar
^ +1
Old Oct 25, 2012 | 04:23 PM
EvoIXJDM's Avatar
Ported intake and exhaust manifolds!
Old Oct 26, 2012 | 01:20 PM
thepoint4life23's Avatar
Like they said get a tune and bigger injecters since your going to need them with a bigger turbo anyway and maybe port the exhaust manifold
sdk1m
Aug 27, 2014 11:35 AM
Jacare
Feb 21, 2014 11:17 AM
asevo9
Mar 28, 2013 02:58 AM
mygsr
Mar 20, 2013 11:08 PM
fireroasted
Nov 8, 2012 05:54 AM
