New clutch installed car moves by it self
Old Nov 7, 2012 | 01:58 PM
Evo03Rt's Avatar
JUST PUT IN A NEW CLUTCH AND THE WHEN YOU START THE CAR UP IT STARTS TO MOVE BY IT SELF WITHT THE CLUTCH UP AND WONT GO IN TO FIRST GEAR LMK IF YOU KNOW WHAT IT CAN BE BLEED THE CLUTCH ALSO ADJUSTED THE PEDAL ANY IDEAS.
Old Nov 7, 2012 | 02:00 PM
SavageEvo8's Avatar
adjust the pedal
Old Nov 7, 2012 | 02:13 PM
Evo03Rt's Avatar
i DID NUMEROUS TIMES NOTHING CHANGES
Old Nov 7, 2012 | 02:21 PM
ezzey's Avatar
you look up any video's and make sure you're doing everything properly? There's a real nice video that explains how it should be adjusted properly. Sounds like you just need to make the proper adjustment.
Old Nov 7, 2012 | 02:30 PM
Evo03Rt's Avatar
Where are the videos at... Ive done it before not my first time doing a clutch...
Old Nov 7, 2012 | 08:01 PM
icmanevo's Avatar
Interested in the video too if anyone has a link. I get lockout but I didn't adjust it after I put my new clutch in.
Old Nov 7, 2012 | 09:17 PM
fireroasted's Avatar
Make sure the clutch line is bled properly, as it can hide air easily if you took the line off. Also make sure you adjust the rod itself to control the travel of the pedal. I ran mine 'adjusted' for about a year until I finally got it correct. 1 trans rebuild later. Now it's perfect, but the rod is pretty much maxed.
Old Nov 7, 2012 | 09:21 PM
http://www.4g63turbo.com/tech/eclips...djustment.html
I always liked this page in case functional detail helps. Make sure too that when you bleed the line you have one one pushing back against the rod of the slave cylinder so the air can't trap in the cylinder itself as the lowest or furthest point.
Old Nov 7, 2012 | 09:24 PM
Evoryder's Avatar
if its' a twin disc clutch and you A: didn't put the retainer clip properly or B: Did not put the clip at all. THen you will have the issues you described. If bleeding the system and adjusting the pedal doesn't do anything, then your clutch is not disengaging.
Now, the throw out bearing could be off too...
bbong
Jun 11, 2017 05:25 AM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
RalliMark
Nov 5, 2013 09:38 AM
4G63 4EVR
Jun 6, 2013 04:25 PM
curamrdan
Apr 10, 2013 03:46 PM
