Stupid question but lag in power??!!
Old Nov 8, 2012 | 01:34 AM
Seamus7's Avatar
Exclamation Stupid question but lag in power??!!
Sometimes when I'm driving around town I can hear the turbo spooling but can't feel the "pull" at all from it, as If it's just spooling and I'm running on a 2.0 motor, every once in a rare blue moon a get a random misfire but I don't think that's it, I'm leaning towards some sort of major boost leak but as I check for that, any other suggestions guys?
Old Nov 8, 2012 | 07:28 AM
evo8426's Avatar
What turbo?
Old Nov 8, 2012 | 10:22 AM
icmanevo's Avatar
boost leak.
Old Nov 8, 2012 | 04:22 PM
Seamus7's Avatar
Stock 16g turbo
Old Nov 8, 2012 | 04:31 PM
meckert's Avatar
and what are the conditions when you can make this happen. RPM, GEAR Throttle position etc.
Old Nov 8, 2012 | 07:57 PM
Seamus7's Avatar
While driving..... About 2500 Rpms and up til about 5k rpm or so and then I'll feel the pull it kicks in like it's been holding back, 2nd gear 3rd gear 4th doesn't matter,
Old Nov 9, 2012 | 07:35 AM
Canadian-Ix's Avatar
Sticky wastegate or bov possibly.
Old Nov 9, 2012 | 11:47 AM
4g63Moon's Avatar
Do u have a boost gauge and a wideband? If so look at ur boost gauge at WOT and same with wideband to see if ur running a lil lean or too rich. I'd also check the couplers too
Old Nov 9, 2012 | 01:08 PM
Chef-j's Avatar
Check for the leak. It is very important to look at your boost gauge and wideband when it's happening.
Old Nov 15, 2012 | 05:53 AM
Seamus7's Avatar
98% stock no gauges or anything but I with install one with in the next day or 2 so I can monitor
Old Nov 15, 2012 | 05:56 AM
Aby@MIL.SPEC's Avatar
1st, get a boost gauge to see where your at. you can remove it if you want to.
if your going to sort it out blindly, replace plastic bov with metal evo9 bov & try a different oem ebc.
juyanith
May 25, 2014 02:35 AM
Seamus7
Jan 31, 2013 04:07 PM
detroitms3
Apr 10, 2011 08:58 PM
BiggsEvoX
16
Feb 25, 2011 10:03 AM
lan_evo_mr9
E85 / Ethanol
63
Dec 20, 2010 10:45 AM
