Shifter Lever pin cut in half?
Old Nov 29, 2012 | 02:16 PM
bone100's Avatar
Hello all,
Since I purchased the car back in 08, I have noticed really notchy shifting and sometimes not being able to go into 1st from neutral. ( I would have to go to 2nd first). I figured it was normal evo tranny notchiness.
So recently I have had issues where going into 5th gear would be 3rd and reverse would be 4th. With the help of Trevor from Sheptrans ,Tim Zimmer from TMZperformance and Greg from USC Performance , I was able to find out the pin which holds the white half moon piece that allows the tranny to move to the right shift gates (5th-reverse) was cut in half. This didn't allow the white plastic piece to sit securely on there.
After replacing that lever and a new white plastic piece, it feels like a totally different transmission. More of like my friends RSX-S trans. I have to re-learn how to shift again because it's so precise. I also have underhood shifter bushings which probably help a lot.
Has anyone ever seen this before??
Pics:
Attached Thumbnails Shifter Lever pin cut in half?-shifter-lever.jpg   Shifter Lever pin cut in half?-2012-11-28-10.26.43.jpg   Shifter Lever pin cut in half?-2012-11-22-08.36.18.jpg
PeteyTurbo
205
Dec 10, 2024 06:04 AM
Mcstikman
Mar 17, 2024 09:51 AM
Andrew Leinen
Lancer How Tos / Installations
Jan 30, 2017 05:22 PM
Trever007
Mar 27, 2015 11:37 PM
EvoCorp
Jun 17, 2005 07:43 PM
