Clutch sensor or starter solenoid?
Old Dec 19, 2012 | 02:49 PM
reylovespayia's Avatar
Question Clutch sensor or starter solenoid?
Anyone know where I can buy a cheap new or used clutch sensor and starter solenoid?
My car does not start sometimes or it takes awhile for it to start...
Before I buy, is it the clutch sensor or the a
Starter solenoid? Is there even a starter solenoid? Lol
Old Dec 19, 2012 | 03:06 PM
okevolutionVIII's Avatar
There's a starter solenoid, I had my rebuilt one go out after 1200 miles and it starts out by acting like a weak battery when cranking over, just gets worse & worse until it's done. Installed a used one today and it's all good now.
Old Dec 19, 2012 | 03:30 PM
When i turn the ignition, it doesn't loose any power or weaker.
I turn on the key, let all the lights comes on first, I put my car I'n gear and starts it.
It starts most of the time, but in some days, it takes more than 5 tries.
Where did you buy your starter solenoid and for how much? Thanks
Old Dec 20, 2012 | 07:06 AM
Did I post on the right section? No one seems to know. Lol
Old Dec 20, 2012 | 10:10 AM
I ended up buying the whole starter on eBay for $70 which is cheaper than any I see on the forum. IIRC, the a bad starter will draw power making the interior light go dimmer when trying to start and a bad clutch switch will simply act as I the clutch isn't engaging the switch.
Old Dec 20, 2012 | 08:39 PM
hiboost2.0's Avatar
You can unplug the clutch switch beneath the clutch pedal to see if the problem persists. Same thing happened to me. Just don't leave the car in gear if you ever start it without the clutch!
Old Dec 20, 2012 | 11:02 PM
Thanks for the tip peeps!!!
luvboost
May 5, 2014 08:26 AM
MurderedOut09
Jan 23, 2014 12:35 PM
ptm5070
12
Jan 9, 2014 12:19 PM
holmes14
Oct 30, 2010 10:56 PM
kalpakiotis
Lancer Troubleshooting
May 11, 2010 02:50 PM
