Engine seize?
Old Dec 20, 2012 | 07:48 PM
NY Evo's Avatar
Engine seize?
How do you know when engine is seize? Car drove perfect to school then wouldn't start. Makes a long screeching sound coming from engine no clicking whatsoever from starter. Help plz
Old Dec 20, 2012 | 08:12 PM
sktng22's Avatar
you sure that isnt the starter making the screeching sound? if you want a sure way to check that the engine is seized or not then turn the crank bolt
Old Dec 20, 2012 | 08:17 PM
4RETECH's Avatar
If noise sounds like a high pitched grinding your starter flywheel teeth might be sheered off. Again. as someone said, just turn the crank by hand and that will tell you if the motor is free.
Old Dec 20, 2012 | 08:22 PM
barneyb's Avatar
With the passenger side wheel off, find a large rubber plug in the fender liner. Put the removed wheel under the car so the car can't fall on you. Pull the plug and insert a 1/2 inch drive extension into the crank bolt. But, first of all, check the oil. Usually, an engine won't seize if it contains oil.
seized
Australian Forum
46
Feb 17, 2019 05:18 PM
mkhalid
11
Aug 15, 2013 09:51 PM
trans_lux
Jan 9, 2009 03:51 AM
Creamo3
33
Oct 1, 2006 05:28 AM
seized
Sep 25, 2003 02:59 AM
