evo 8 engine alternative
Old Dec 22, 2012 | 12:03 PM
buford's Avatar
Hey guys.
After fooling around with DSM's for the past 5 years, I finally got an opportunity to purchase an evo. Problem is, it has a trashed motor, but for the price I couldnt pass it up.
The head and block are trashed. Therefore I am in need of a new engine. I have been doing some reading about alternative engines to use such as ones from an evo 5-8. My question is, if I purchase an evo 6 engine, could I just swap everything externally on the motor from my evo 8 engine and bolt it in?
The reason I am looking at the evo 6 engine is because I plan on going forged internals and the evo 6 engine is a lot cheaper than an evo 8 engine. I hate to spend the extra money on an 8 just to rip it apart and build it.
What are some hickups (if any) that I might encounter by going this route? Thanks in advance.
Old Dec 22, 2012 | 01:03 PM
todd6027's Avatar
swap over inlet manifold and bracket with canister / flywheel & clutch / pas pump mounting bracket , use the evo6 steel water pipe from pump / stat housing and thermostat
Old Dec 22, 2012 | 05:06 PM
buford's Avatar
That it? Everything else is interchangable? Im assuming I would have to use my evo 8 cams for the CAS. Everything else wiring harness wise should work fine?
Old Dec 22, 2012 | 07:41 PM
2001gslp's Avatar
That, or if you're already going to be building the motor, do a built 64 bottom end with a kia head (I know I'm gonna get flamed) or find an evo head. Bigger combustion chambers in the kia/hyundai, so you essentially get a free port job, and everything is a bolt up application (this is going to be my exact build btw). That's just my two cents.
Old Dec 22, 2012 | 08:03 PM
buford's Avatar
Coincidental enough, I actually have a freshly rebuilt Kia head with evo 8 valve train in it and a 4g64 block/crank in my garage. I don't really feel like messing with the timing or water pump and I want to stay 2.0 so I will be selling those if anyone is interested.
Old Dec 22, 2012 | 08:30 PM
2001gslp's Avatar
If shipping ain't too bad pm me on the block and crank to 01056. With the timing part of it, you use the 94 galant gs 4g64k timing belt and adjust the gears accordingly, wich isn't hard. 64's are torque monsters too. :giggitty:
Old Dec 22, 2012 | 10:56 PM
buford's Avatar
I have searched and read a lot about the timing on the 4g64. Can anyone verify 100% what I need to do in order to time it? Can I just use the 94 Galant dohc cam gears and timing belt?
Old Dec 23, 2012 | 09:25 AM
2001gslp's Avatar
All you need is the 94 galant gs timing belt and at least one adjustable timing gear.
Old Dec 23, 2012 | 01:49 PM
todd6027's Avatar
you can use the 6 cams and cas no issues
MikeB@FFTEC
36
Nov 4, 2019 05:23 PM
fel222
Mar 31, 2014 11:12 AM
R15
Jan 27, 2013 09:28 PM
wickj_7399
Nov 28, 2012 06:00 PM
