My Check Engine Light Comes On
Old Feb 10, 2004 | 07:05 AM
WEIGHTLESWHITE8's Avatar
does anybody else have ths problem? i just installed my exhaust, intake, downpipe, bov and an mbc and now my cel comes on. my brother tells me it is the ecu and i need to change it because the chip does not recognize the parts i just put on. the car runs fine but i can't stand looking at the light...
if i do need to change the ecu, where can i get a new aftermarket ecu for my evo 8?
thanks
Old Feb 10, 2004 | 07:08 AM
kuniboy's Avatar
Did you drive the car yet? how does it drive?? ok nevermind, the car drives fine. No your brother is wrong, there's nothing wrong with your ECU. do you have a cat delete?
Old Feb 10, 2004 | 07:20 AM
nastea's Avatar
don't post in all caps either.
just reset your ecu... disconnect the negative terminal on the battery... for 3 seconds
Old Feb 10, 2004 | 07:41 AM
mifesto's Avatar
i would recommend more then 3 seconds .. more like 5 minutes to make sure grounding is fully discharged etc... but yeah i had the same problem and i think its just the weather messing with your intake and ecu. no worries just clear the message
Old Feb 10, 2004 | 09:14 AM
en1gma19's Avatar
are you running catless....that combo of mods shouldn't throw a CEL unless you don't have a cat....get the code pulled before you reset it......just in case....better safe than sorry!!!!!
Old Feb 10, 2004 | 09:35 AM
SubEd's Avatar
I don't understand why people are so quick to reset the CEL, without knowing what triggered it.
Old Feb 10, 2004 | 09:37 AM
nastea's Avatar
well i guess is personal preference, i have faith in my car...and know what i'm doing, most of the tiem i get the random misfires, a few times i've gotten overboost....
if its a serious problem, i'm sure it will come on again.
Old Feb 10, 2004 | 09:47 AM
jess's Avatar
go to an auto zone and pull the code for free, then if it's not serious fix it and reset the light by disconnecting the negative lead to your battery for no less then 10 seconds, if you didn't fix the problem the service engine light will eventually come on again.
Old Feb 10, 2004 | 10:14 AM
M3lachsilber's Avatar
choad
I'm no "tuner" but I have certainly learned a lot by reading these boards..
Personally, if i threw all that **** on my ride, I would definetaly test fuel, air etc...It would be the ONLY way I would throw that stuff on my car.
I would want to know for sure that the car was processing the changes those mods would encourage, without causing the car to misfire, run too rich, etc.
Not too mention a dyno run to anylize the results..and see if the mods are evn helping without a brain examination..remapping, etc.
I never thought it was a good idea to mod like that WITHOUT having an expert flash or at least tune the ECU to accompany the mods??!!
Old Feb 10, 2004 | 10:26 AM
Az3ar's Avatar
If he has a rase pipe he will get a cell light and there is no problem with that at all. He can drive it all day long with the cell light on. Its a sensor in the exhaust that is reading wrong A/F ratio. Anyways I have a feeling its your BOV either leaking or installed wrong.
wreckleford
Nov 17, 2017 07:07 PM
EVO8speed
Dec 1, 2008 07:05 PM
Evo_Jr
Lancer Troubleshooting
14
Feb 4, 2007 11:06 AM
pumpdog720
Sep 19, 2005 05:58 PM
k270kmh
Jun 1, 2004 04:31 PM
