Tial mvr 44 questions
I am going to be running a grimspeed 3 port ebcs and want to know if I should leave the top 2 ports open and use one of the bottom ports and plug the other lower 2 ports? I am also wondering what psi spring setup should I run if I plan on running 30 psi on a 6466?
you will typically run boost to the bottom port and the controller to the top port. Rule of thumb is that you can run boost up to double the spring pressure. I would recommend an 18psi setting although i personally run 24psi springs on my twin mvs's for daily 30-33psi.
ChrisWantsBoost
Jan 2, 2015 09:04 PM
My03evo
Apr 8, 2013 02:37 PM
dvd_mi
16
Nov 19, 2009 05:27 PM
