Two different Boost Reading
Old Feb 8, 2013 | 08:23 PM
EvoIXPilot's Avatar
I have a autometer Phantom boost gauge and Greddy Profec B Spec 2. The two have different readings. At idle, the autometer reads -13ish while Greedy reads -6ish. When the engine is off, the autometer is at 0 while greddy is -2. How can I get these two to sync? which one should I trust?
Old Feb 8, 2013 | 08:44 PM
codgi's Avatar
If the engine is off then it should read 0. Neither is going to be super accurate unless they support a way of calibrating them for your particular elevation. So just use them to give you a rough idea of what your boost is but very likely they are +/-1->3psi off
Old Feb 8, 2013 | 08:52 PM
flymx771's Avatar
Your Greddy gauge is about as worthless as a flat tire!
Old Feb 25, 2013 | 05:53 PM
EvoIXPilot's Avatar
Update: When in vacuum, the autometer phantom gauge reads in hg while greddy reads in psi. When i use a converter, its very close...off by 1 or so. Basically, it was two different measurement units!
PHILLY EVO
Jan 5, 2014 03:56 PM
Toole
Jan 16, 2013 03:36 PM
an0ther
Sep 16, 2005 08:19 AM
rt turbo
Dec 11, 2004 11:19 AM
lynkz
10
Jan 4, 2004 12:10 PM
