9 turbo vertical shaft play question
Old Feb 17, 2013 | 11:25 AM
PatricksEvilEvo's Avatar
Ok guise I've searched and everyone talks about horizontal shaft play (in and out). Mine's perfectly tight that way but it does move slightly up and down. Is this something to be concerned about?
Old Feb 17, 2013 | 12:28 PM
BEKevo's Avatar
There is actually an acceptable range of "vertical" movement.. I can get you the specs if youd like to measure.. Slight movement is nothing to be concerned of, just make sure the compressor blades aren't hitting the housing.
Old Feb 17, 2013 | 12:30 PM
todd6027's Avatar
not a concern , when running the oil pressure floats the shaft
Old Feb 17, 2013 | 12:32 PM
Thanks guys, yea it's very minimal but it doesn't hurt to ask before I put everything back together. Blades definitely aren't touching the housing.
Old Feb 17, 2013 | 01:11 PM
mt057's Avatar
Sounds like you are good. A couple mm up and down are ok if it is not touching at all or smoking before you took it apart.
Old Feb 17, 2013 | 01:25 PM
Nope no smoking or anything.
yeayeaatou
Jun 5, 2015 12:06 PM
mitsubeastlee
Oct 5, 2014 07:01 PM
jyamona
Mar 6, 2013 05:56 PM
elphalba
16
Oct 11, 2010 07:27 PM
~Evil_Evooooo~
May 5, 2010 03:57 PM
