Buschur stage 3 head vs Wiseco e85 pistons
Does anyone have experience running the Buschur Stage 3 head with the larger valves against an off the shelf, Wiseco e85 piston?
I'm concerned that the larger valve sizes may cause a clearance issue for me.
-Alex
-Alex
I guess I'll find out after everything is ordered. I don't want to have to flycut these pistons or buy new ones.... But If i have to, oh well.
-Alex
can you use max mivec advance with a buschur stage 3 head 0.5mm oversize valves and s3 cams, with 1400HD 10.5CR pistons? How can you check piston to valve clearance for max mivec advance?
