2.0L build, need advise.
Old Mar 28, 2013 | 11:50 PM
babaz7's Avatar
hi im doing a 2.0l build and need some advise from members.
first of all,im planning to get GRP aluminum rods, but i dont know what bearings i should choose with them, secondly what rod bolts would be best for them?
and what compression piston would be best for 93 oct with 30 psi boost?
i want GRP aluminum rods, but cant decide a piston, what is the best pistons i could buy?
thanks...
Old Mar 29, 2013 | 02:20 AM
babaz7's Avatar
okay so i found these rods... http://www.extremepsi.com/store/prod...roductid=21527
the website says to use clevite 77 rod bearings and arp 8740 rod bolts, but cant i use arp 2000 rod bolts i think they are high end and better than arp 8740 right?
i have the cash ready i just need you guys to adress my questions so i can order the stuff, and please mention also what will be the best pistons to go with grp connecting rods..
Old Mar 29, 2013 | 02:30 AM
foxbat's Avatar
Bearings: ACL or Cosworth, both are good.
Usually, aftermarket rods include quality aftermarket bolts, if not then get ARP bolts, I also recommend that you install ARP head studs.
Pistons: JE or CP or Wiesco, are all equally excellent & cost less than Japanese brands. Get stock or near stock compression 8.8 or 9.0.
You'd need to examine cylinders walls & level of wear to decide what piston bore to get.
Old Mar 29, 2013 | 03:25 AM
babaz7's Avatar
thanks for your reply, so any bearing and rod bolt will fit basically, and not the one's only stated by the magnufacturer ?
if i get ARP 2000 rod bolts and acl race bearing will they work with GRP rods?
and secondly how do i examine cylinder walls and compression?
Old Mar 29, 2013 | 03:45 AM
way2qik's Avatar
Are you building this engine yourself or are you having someone else build it?
Old Mar 29, 2013 | 04:31 AM
babaz7's Avatar
someone else will build it, but unfortunately the country i live in,over here they have no concept of clearences and taking mearusements,they just drop everything inside and hope for the best..
i'll just take measurements..
Old Mar 29, 2013 | 07:26 AM
babaz7's Avatar
just took cylinder compression test:
results
148
152
148
148
those look fine right?
and guys please answer my above questions i asked!
Old Mar 29, 2013 | 06:20 PM
babaz7's Avatar
bump!
Old Mar 29, 2013 | 07:22 PM
przemekwid's Avatar
bump
Aniel
Oct 24, 2016 05:08 PM
babaz7
20
Jan 28, 2013 07:29 AM
babaz7
Aug 11, 2012 06:42 AM
Evokid03
Feb 20, 2011 04:18 PM
AWD Motorsports
98
Sep 9, 2010 06:25 AM
