Hard pull in 1st gear, backfires now won't start
Old Jun 3, 2013 | 11:42 AM
redrocket03's Avatar
Hey guys I recently did a hard 1st gear pull in my Evo 8 and as it guy up in the higher rpm range it backfired very loud and just pretty much lost all power. I checked all my intercooler piping all was intact. Compression test showed good considering my starter is on its way out and wouldn't let me crank the car long. I logged it as I was starting it and showed 22 timing errors within 5 seconds. Checked the timing marks and everything was still dead on. Anybody got any ideas what could be the problem? Fuel pumps are both good and all the other small things I checked.
Old Jun 3, 2013 | 11:59 AM
evobros's Avatar
Backfire like through the TB?
Or after fire through the exh?
Old Jun 3, 2013 | 01:05 PM
Thru the exhaust it sounded like lol it all happens so fast now it's almost hard to tell
Old Jun 3, 2013 | 01:10 PM
SilverShadow03's Avatar
Have you tried resetting your ecu by unplugging the batter for a bit?
When you checked your timing marks, were they checked at the valve cover or down below at the crank too? Make sure you check ALL Timing marks...
Boost leak?
Old Jun 3, 2013 | 01:14 PM
Nah I didn't try resetting the ecu I didn't figure it'd make any difference with me being on aem. I checked both the crank and timing gears
Old Jun 3, 2013 | 04:28 PM
loch's Avatar
check ur cam and crank angle signals one may be damaged
Old Jun 3, 2013 | 08:32 PM
Went ahead and took the car to shift fast Motorsports in rock hill sc they found out the crank trigger plate was damaged. Replaced it now it runs like a champ. Thanks guys for your input and replies
Old Jun 5, 2013 | 08:45 PM
Turns out something hit my crank trigger plate and got my crank sensor as well. All that's fixed now but now Im dealing with my turbo damaged due to oil starvation from a hole in my line.
Enjoi926
May 31, 2017 06:47 PM
Ekoy
AEM EMS
27
Mar 29, 2017 10:21 AM
yang123
14
Sep 18, 2007 03:15 PM
DRAG
Feb 27, 2006 06:19 AM
ultraflip
23
Feb 23, 2005 01:12 PM
