WAS just about done with my installs....
Old Jun 13, 2013 | 06:17 PM
brokenRS's Avatar
Just got done putting in cams, springs, and retainers. Everything lined up and looks good. Only thing i had to do left is release the tension on the timing belt.
Everything was done properly, the tool had anti seize treatment before using. Inserted and turned 30 degrees and allowed the tension to set before turning again. Backed it out slowly and surely, then it snapped. ****!
So now i have the TIP of the tool stuck in there..
Whats my best solution for this?
Old Jun 13, 2013 | 10:23 PM
240Z TwinTurbo's Avatar
I had the same thing happen and had to pull the front timing cover to remove. It likely got bent from being tightened too much and became warped. When I got to mine it unscrewed by hand and did not cause any damage.
Old Jun 13, 2013 | 10:47 PM
brokenRS's Avatar
Yeah i am going to pull the timing cover off tmrw morning. Hopefully i can remove it with ease.
I didnt tighten too much, not more then 20ft-lbs. only enough to give me a tiny slack to remove the cam gears off the shaft itself.
Old Jun 13, 2013 | 11:03 PM
SaulHudson's Avatar
#2 easy out.
http://www.sears.com/craftsman-10-pc...1&blockType=G1
Old Jun 13, 2013 | 11:23 PM
brokenRS's Avatar
Saul,
That tool probably wont even reach it.
Old Jun 14, 2013 | 01:16 PM
SaulHudson's Avatar
Originally Posted by brokenRS
Saul,
Put a socket and extension on the end it, its a 4pt head.
Old Jun 15, 2013 | 03:59 PM
okevolutionVIII's Avatar
How hard did you tighten it down in there? It needs to be threaded about a half turn every 10 seconds or so to slowly compress the tensioner or it can cause damage to the threads.
I would drill all the way though it to make sure the EZ Out grabs really good and a small torch to heat up the surrounding metal should help as well.
Old Jun 15, 2013 | 11:09 PM
SaulHudson's Avatar
This is a bad idea when you are trying to easy out something.
Heat expands, when you heat up the metal it puts more pressure on the threads...
Its different if you have a head to turn and are trying to break loose a rusted bolt, but this is a clean bolt, heat will only make this harder.
steveyrich
11
May 20, 2016 07:21 PM
steveyrich
For Sale - Part Outs
27
Apr 7, 2016 10:09 PM
brokenRS
25
Jun 10, 2015 03:46 PM
brokenRS
11
Nov 23, 2014 11:01 AM
brokenRS
Oct 9, 2013 08:28 AM
