Engine won't turn, even by hand
Old Aug 11, 2013 | 08:02 PM
Evo VIII 4o1's Avatar
I did a quick pull on the highway. After the pull, I heard light tapping. I took the off-ramp , was driving slow, and noticed the temp gauge was 3/4 up. I sped up a little and the temp went back down to normal. Then loud knocking and the engine shut down. It wouldn't turn anymore. It seems like its binding or something is keeping it from turning. I can't move it all by hand. I took the accessory belt off and all pulleys spin freely. I took timing cover off and everthing is timed and tensioned. HHEEELLLPPPPPPP
Stage 1 cylinder head rebuild
GSC exhaust valves
ACL Rod/main bearings
Manley Evo 8/9 9.0:1 Pistons
Manley Evo 8/9 Connecting Rods
Balance/weigh assembly
FB Green 73HTA (journal bearing) ported
Grimmspeed EBCS
JDM map sensor
FIC 1450cc injectors
BR Double Pumper
ETS 3.5" FMIC
TurboXS intercooler piping
Synapse Synchronic BOV (recirc)
84mm FP intake w/ HKS suction filter
MAP o2 dump
Helix downpipe w/invidia test pipe
Apexi Noir (WS2) exhaust
GSC S2 cams w/manley springs
ARP headstuds
Old Aug 11, 2013 | 08:03 PM
I also drained the oil and there were no metal flakes in it
Old Aug 11, 2013 | 08:10 PM
02-Lancer-Es's Avatar
Try to hand turn it with the clutch pedal in , if no go pull the timing belt cover and make sure the timing belt didnt come apart . Tried hand cranking it counter clockwise ? Ive seen the same issue on a Evo before when a main bearing locked up and there was no metal in the oil .
Old Aug 11, 2013 | 10:25 PM
Jerry321's Avatar
^^ It's possible the main bearing seized like 02lanceres said but the pistons might have seized to the cylinders too. How much oil came out? Could have been low on oil and that could have caused the seize.
Old Aug 12, 2013 | 06:55 AM
I got the motor started. It soulds like this. Like something is bouncing around in the head. It gets louder as you rev it
Old Aug 12, 2013 | 07:11 AM
BlackonBlack2's Avatar
I would say rod knock.... but valve train should be fairly easy to check... just pull the valve cover off and make sure everything seems about right(springs, retainers, keepers, rocker arms) did you bleed the lifters... even though I don't think it would end up sounding like that... and double check timing... but doesn't sound well at all..
gl
Old Aug 12, 2013 | 07:19 AM
Bruzewski's Avatar
Definitely pop off the valve cover and check the springs and rockers.
Old Aug 12, 2013 | 07:24 AM
joseph143's Avatar
I'm 99% certain nothing in the valve train can cause that sound... Especially not being mivec. If your timing jumped maybe but if that were the case it wouldnt magically unlock itself... To me it sounds like a rod came apart...
Old Aug 12, 2013 | 07:27 AM
I already popped the valve cover and everything was in check. lifters have pressure, everything lined up and tight. I am gonna drop the pan tomorrow and take look around. I will check back tomorrow
Old Aug 12, 2013 | 07:29 AM
chu's Avatar
chu
That sounds terrible. Pop the valvecover and the oil pan imo.
Old Aug 12, 2013 | 09:11 AM
TommiM's Avatar
Take the spark plugs out and shine a light down there if you don't have access to a boroscope. If nothing obvious at least it should be easier to spin without the plugs. If it still wont budge then defintaly pull the pan. That should tell you for sure whats going on.
Old Aug 12, 2013 | 09:18 AM
punxnotdead185's Avatar
Crank walk?
Old Aug 12, 2013 | 09:45 AM
Dvolution's Avatar
^lol
Old Aug 13, 2013 | 09:57 AM
Gold flakes in the oil. Pulled pan and found Cylinder #2 rod/crank bearing gone. Can she be saved?I can bounce it around with my fingers
Old Aug 13, 2013 | 01:18 PM
chu's Avatar
chu
Time to rebuild the block man. Sorry. I went through 9 months ago myselft; spun rod bearings 1 and 3 on a road course.
