Fp Black ???
Fp Black ???
Confused on what setup to go with..
HP Goal: 620whp
PSI: 35psi max
Supporting Mods to make 620whp: Yes
Fuel: Dual Map 93 octane / E85
Current setup: HTA fp green
Current WHP: 429whp @ 27psi
Here is where I am confused, should I go with T3 setup or stick with what I currently have but switch to FP BLACK ?
HP Goal: 620whp
PSI: 35psi max
A 35r or a black will get you where you want to be at. The power and spool will come in at different times between the turbos.
What is actually done to support this power? If you have a stroker, a 35r would be up your alley. If you have a 2.0, you may want to go with a black.
On my 2.4, Im making around 650whp and 580tq at 36psi on e85 with a black. If I wanted more Id go with a 35r.
FS[Northeast]: FP Black Ball Bearing MHI + Accessories $2100
Seidelly
Feb 19, 2017 01:45 PM
evo8vz
Aug 4, 2016 05:00 PM
Carloverx
36
Sep 29, 2014 08:17 PM
06MRV8Killer
Sep 5, 2014 04:14 PM
