what kind of coolant?
Old Apr 25, 2004 | 06:12 PM
bishiboy's Avatar
If you aren't in an area with any chance of freezing, straight distilled water with waterwetter is the best. The water has higher cooling abilities than 50/50 mix of antifreeze/water. The Waterwetter makes the water "slippreyer", lubricates the waterpump and reduces air pockets (steam pockets).
Old Jun 17, 2004 | 06:04 AM
x7eVoLuTiOn7x's Avatar
I noticed my coolant tank was also lower than minimum. Should I just add 50/50 coolant/water? or just distilled water? My coolants color is brown.
Old Jun 17, 2004 | 06:43 AM
mayhem's Avatar
Wouldn't you want some AF for the anticorrosive properties.
Old Jun 17, 2004 | 04:21 PM
k270kmh's Avatar
I would go with 35 Mitsubishi anti freeze / 65 distilled water + Red Line Water Wetter.
I don't know if it is placebo effect but I put reline WW in 3 different cars and I felt an improvement in the top end. I didn't notice a decrease of temperature because it is controlled by the fan and thermostat.
Obs: If someone knows bad things about Water wetter pelase let me know.
Old May 5, 2010 | 04:38 PM
shrty10135's Avatar
i put prestone 50/50 mix coolant in mine from autozone it says you can mix with any color coolant and it works on all makes and models. is this ok?
Old May 5, 2010 | 05:40 PM
RunThat's Avatar
Distilled water and water wetter in spring and summer til it starts getting cold (30's), then switch to antifreeze. Easy.
Old May 5, 2010 | 06:53 PM
TommiM's Avatar
Originally Posted by chase
Hey guys...i just wanna make sure what kind of antifreeze coolant should i use to fill up my evo???any specific type?
50/50 or 60/40 mix of distilled water and oem mitsu coolant.
Old May 5, 2010 | 06:56 PM
TommiM's Avatar
I put a little bit of coolant in the overflow tank, and top it off with water. With some coolant in there you wont risk freezing the water and causing the plastic overflow tank to crack.
gilevo7
May 20, 2017 10:55 PM
sktng22
13
Dec 9, 2013 06:22 PM
Yamahar1
Jun 28, 2011 03:19 PM
justchil
19
Dec 19, 2010 08:23 AM
nnorris7413
16
Jun 28, 2005 05:34 PM
