For Those Looking For a Wideband o2
Old Apr 15, 2004 | 10:52 AM
MrBonus's Avatar
Originally posted by juyanith
Yeah it sure could. I have heard of at least one Evo owner who had the LM1 tucked away in the glove box.
Yep you can use it by itself. It is designed to work exactly as you describe (weld a bung and run wire to the controller).
It has a record/datalog function, correct? It would be fantastic to use with my SAFC as I could simply tune on the road without plugging it into my laptop to view the graph.
Old Apr 15, 2004 | 12:36 PM
juyanith's Avatar
Yeah, but it would be hard to watch the display and drive at the same time (the display is not that big). Why not take the laptop along and at the end of each run download the data and use it to make your changes? I guess if you really want to do it without the laptop you could either get their gauge or use the adapter to plug into one from another manufacturer. This is akin to what I was looking to do, but I think I'll wait a little while to see what they announce for their "permanent install" solution.
Old Apr 16, 2004 | 12:41 AM
Sunder's Avatar
What you guys think of this?
http://www.techedge.com.au/vehicle/wbo2/wbo2.htm
It's more expensive, but it's in Australia, so I have less of a hard time getting it.
I also have two cars I want to tune with it, does that mean I buy two sensors, or can I somehow calibrate it to read after the the cat? (Obviously it's leaner after the cat, but we could always compensate)
Old Apr 16, 2004 | 06:43 AM
nothere's Avatar
I think you will want to put a bung before the cat, on both cars then swap the setup, the sensors don't like not being powered.
so you remove the sensor if you are not useing it.
Old Dec 8, 2004 | 10:57 PM
HxllxMan's Avatar
Where can I get the Innovate LM-1?
I can't order on the official website, they don't ship to Hawaii.
Old Dec 8, 2004 | 11:13 PM
JustDSM's Avatar
AMS is an authorized dealer.
Old Dec 11, 2004 | 04:51 AM
EVO8LTW's Avatar
I got mine from EIP Tuning in Maryland.
