Anyone ever tried this tool for measuring valve stem height?
Like the title says I am wondering if anyone has tried this tool for measuring the valve stem height in the head.
http://www.silver-seal.com/c=D6rH029...00---1800.html
It says it works for most 4&6 cylinder vehicles and the measurement range should cover the height recommended for most valve springs in our head. But I know that often on this car clearances are very tight on this car so I am wondering if it would even fit. But if it did fit our cars it would definitely make taking those measurements a million times easier than a depth mic and stem height tool. Thanks for the input.
Simply put, No that will not work. The OD of the tool it too big to fit in a 4g style head.
It is designed to work in a OHV set up not a OHC.
It is used to measure valve spring installed height, NOT valve tip height
BR350VIII004
Apr 21, 2016 08:43 AM
tsidrift1
23
Nov 9, 2013 06:10 AM
lostsoulsevo
Aug 6, 2012 07:24 AM
