EVO IX Turbo
Old Mar 8, 2014 | 01:10 AM
wowzers's Avatar
EVO IX Turbo
HI guys,
Quick question;
at what RPM does the stock turbo exactly, kick-in?
Old Mar 8, 2014 | 02:39 AM
evodriver49's Avatar
Originally Posted by wowzers
HI guys,
Quick question;
Are you talking about full boost? It really depends on your setup. With aggressive cams itll cause lag and with porting itll help spool. Ive seen as low as 3000rpms (EVERY PART was ported top to bottom on the car) up to 3700 from my experience. Safe to say around 3500 on a typical setup
Old Mar 8, 2014 | 03:39 AM
wowzers's Avatar
Yeah stock engine, turbo and ECU. when it first kick in…
i haven't had the car very long, but off boost from 1,500rpm - 3,500…that car feels pretty sluggish and dull
the only thing different is the 20PSI turbosmart actuator.
So im guessing 3,500RPM
Old Mar 8, 2014 | 06:45 AM
josh_evo9's Avatar
I agree, roughly 3500rpm.
Old Mar 8, 2014 | 07:22 AM
b boy's Avatar
Veteran: Air Force
usually you will start boosting around 3200rmp and 3500rmp but aftermarket parts can change those numbers and tune can also change those numbers
Old Mar 8, 2014 | 09:31 AM
cmspaz's Avatar
You can get a IX to spool the OE turbo in 3rd at 2900 if you mess with MIVEC enough. On an VIII they'll spool around 3500.
Old Mar 8, 2014 | 02:35 PM
wowzers's Avatar
I suppose the lower it kicks in the better the driving will feel…
but for regular driving, no doubt that it will use more fuel…?
Old Mar 8, 2014 | 02:55 PM
foxbat's Avatar
There are different XI turbo types, which type is yours? As an example the XI RS turbo is designed to spool faster, around 300-400 rpm sooner.
If the car feels sluggish/laggy then the first thing you need to check is boost leak.
Old Mar 8, 2014 | 08:09 PM
wowzers's Avatar
Hmmm,
we'll its the 2007' "new model" evo ix…
which is the Mivec with the updated wheels, pedals etc…
Old Mar 8, 2014 | 09:54 PM
Faisalm's Avatar
It's around 3500... I have a stockish evo 9 and I see full boost around 4200 rpm
Old Mar 9, 2014 | 04:55 AM
evo8426's Avatar
Depends what RPM you floor it from, it would be very easy to load up the engine at a very low RPM. Cams are not going to change the spool up on the factory turbo.
blackoutVIII
Dec 6, 2022 09:48 PM
hermesevo8
Nov 17, 2015 06:11 PM
Gazika
May 2, 2015 10:25 AM
Seenoevol
Jan 28, 2015 05:14 AM
vito93
Feb 17, 2014 03:17 PM
