help analyse my head fault plz
http://help.injectordynamics.com/sup...y-id-injector-
No need to guess on whether they are or aren't or if you should or shouldn't here's what ID has to say on the issue.
- Michael
- Michael
Hey guys I emailed Injector dynamics.
He says if car was tuned with the resistor box on it will not cause any trouble with tune.
Only if car was tuned then resistor box was removed or vice versa.
Basically now we waiting on result from the machine shop that did the cylinder head.. I will update you guys once I have that report
Well that kind of contradicts the post from the link below that Michael provided...
- Michael
- Michael
Asking the right questions is important.
Did you ask - "Should I bypass the restrictor box and if I didn't and ran it would I have a problem with the injectors not working properly"
or did you ask "will my tune change if I remove my restrictor box" the assumption may be it's already bypassed but now you're gonna remove it wholesale and rewire the injectors and that may cause a change.
The information you get out is only as good as the information you put in.
-Michael
-Michael
SteezySmiley
Jan 21, 2016 09:31 PM
AutobahnEVO
25
Jul 21, 2014 10:21 AM
42revoincali
12
Oct 14, 2010 12:21 PM
I guess not!
